Author Topic: What did you do for your Mustang today?  (Read 658113 times)
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #100 on: March 31, 2013, 08:00:45 pm »
Drained ,completely stripped out and flushed the radiator in my 65. Only some loose scale came out of the top tank.
Fitted everything back up along with a TEFBA in line filter, refilled and flushed with fresh water twice.The thermostat (160Deg) had opened at about Qtr. gauge.
Drained once again ,refilled with 5Ltrs of NULON 100% concentrate anti freeze / anti boil and topped up with distilled water.
Went for about a 15 mile cruise late today,temp gauge reached about half scale. Pulled up at home to check for leaks, all good!!  :smile01:
Offline skev
« Reply #101 on: April 01, 2013, 09:56:29 am »
Nothing yet, but I'm thinking of heading to Berowa Waters after lunch  :burnout:
67 Convertible
Offline 69_stang
« Reply #102 on: April 01, 2013, 05:49:03 pm »
Swore & cursed at it!!!!! :soapbox:
Looks like we've done a heater core  :ouch:
Sadly,  probably tucked away for winter now  :tissue:
Offline Ash
  • Name: Max Power
« Reply #103 on: April 01, 2013, 05:50:12 pm »
Bypass it and put an extra jumper or pair of socks on  :thumb:  :lol:
Offline chopmgw
« Reply #104 on: April 01, 2013, 07:12:18 pm »
Spent 2 days of my Easter break polishing the beast and applying a sealant.
I can smell oranges !
Michael
Offline Raven
« Reply #105 on: April 01, 2013, 08:32:22 pm »
hey raven, had u considered polishing the tail light panel? i saw one on a 68 at sema and it looked the tits!
id rip into that on a buff and blind those behind u with the glare!
griff
Griff,
I have seen some fancy looking ribbed panels that guys have done. Polishing the panels would be a fair bit of work as they are not finished the best straight out of the box. About a year ago,I had to send a pair back to the states as they were absolute crap. They had gouges from a grinder all over them!!! The pair I have now are from NPD, the other were from CJ Pony. They are bit of a lucky draw when you open the box.
Finished up the rear end bar the letters. The tube nuts in the packaging had already stared to corrode. I will have to work something out.
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #106 on: April 01, 2013, 11:48:20 pm »
yeah i got ya, either way that rear looks sooooo tough with the chrome bar now. wow!
it does seem more often now that the plating quality of some stuff is so 2nd rate, youd have been so pissed to see the tube nuts corroding before you installed them, not after as per usual....
when i got my oval air cleaner it had course wheel scratches over the entire top, it took me hours of wet and dry sanding to get it near a buffing machine then only to hit it with imron black and then repolish the raised sections. bloody hell the stuff we do huh.
looking fwd to seeing it one day mate
cheers
griff
« Last Edit: April 01, 2013, 11:55:57 pm by griff »
you get that .....
Offline Mustangpaul
  • Look before you leap
« Reply #107 on: April 02, 2013, 11:01:05 am »
When you smile at it it smiles back! nice polish
1967 Mustang Convertible with fries and the works, hold the rust, no timber thank you, go easy on the Bondo and I'll have that in Right Hand Drive please.
Offline caretaker65
« Reply #108 on: April 02, 2013, 03:48:36 pm »
As this coming Sunday is All American at Flemington Racecourse in Melbourne.. guessing the old gal will be receiving a descent clean from top to toe..
Not that she really needs it..but the polish will be going on before she gets covered up for winter..
Offline Mustangpaul
« Reply #109 on: April 02, 2013, 04:35:44 pm »
The first couple of coats of clear have just gone on and I have arranged a spray booth and a painter for the next 2 coats of clear to be applied after these two coats have been sanded.
« Last Edit: April 02, 2013, 04:38:22 pm by Mustangpaul »
Offline Salthorse
  • MOCA (Vic) member - 2709
  • Name: Dave
« Reply #110 on: April 02, 2013, 05:45:15 pm »
Replaced a broken brake booster vacuum check valve . . . Thankyou ABS Brakes in Fyshwick for a perfect fitting replacement.
Dave
1969 Black Jade Mach 1 with a 351C, 3v closed chamber heads, Comp Cams and lifters, FMX trans with 2500 stall converter, LSD, Edelbrock Performer 600 CFM, Sanderson ceramic shorty extractors and Flowmaster American Thunder exhaust.
2016 Deep Impact Blue GT manual with Roush exhaust.
I love it, I need it
I seed it
Eight cylinders all mine
Alright hold tight
I'm a highway star
Deep Purple, “Highway Star” (1971)
Offline chopmgw
« Reply #111 on: April 03, 2013, 02:33:29 am »
Looking good mustangpaul  :thumb:
Michael
Offline Mustangpaul
« Reply #112 on: April 03, 2013, 10:48:05 am »
Thanks, I'm looking forward to Friday or early next week when the final clear is applied in the spray booth.
Offline Pete-W
« Reply #113 on: April 03, 2013, 01:56:59 pm »
Put the front seat in, all inside done now and looks and smells awesome. Took it on the road for the first time in 2 years and with the new motor, tri y's, tranny and diff now reconditioned, twin free flow exhaust, it drives like a new car and the exhaust note is mellow music.  Makes all the hard work and fustration worthwile. Now just a few little things to do and all finished. Really look forward to cruising.
Offline 66 Hertz
  • Web Editor
  • SA member #787 MOCSA
    • http://s731.photobucket.com/albums/ww313/ozzyone_photos/66%20GT350H/?albumv
  • Name: Dale
« Reply #114 on: April 03, 2013, 04:08:46 pm »
great news Pete-W...... :thumb:
Paint by IMAGE CLASSIC CARS
build thread...http://www.mustang.org.au/forum/index.php/topic,14043.0.html
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #115 on: April 03, 2013, 07:04:59 pm »
Good work mate, what colour is your car?
Matt
Offline Mustangpaul
« Reply #116 on: April 04, 2013, 11:41:08 am »
The car is off the stands and standing proud, still waiting for final clear coats.
Offline Mustangpaul
« Reply #117 on: April 04, 2013, 02:08:12 pm »
With or without air conditioning?
Offline Gretschem
« Reply #118 on: April 04, 2013, 02:17:50 pm »
Looks great buddy, why don't you spray the next 2 coats in the booth ???
Offline Mustangpaul
« Reply #119 on: April 04, 2013, 06:37:34 pm »
We have the car ready for towing on Monday morning. It is going into the spray booth then.
Offline Raven
« Reply #120 on: April 04, 2013, 09:14:03 pm »
Looking real good mustangpaul :thumb:
Installed my door mirrors.
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #121 on: April 05, 2013, 01:35:46 am »
Coming along in leaps and bounds fellas!!
Both looking great, catch you on the weekend Dino,
Matt  :thumb:
Offline Mustangpaul
« Reply #122 on: April 08, 2013, 09:48:49 am »
Nice mirrors Matt, my car is at the spray painters today.
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
« Reply #123 on: April 08, 2013, 02:06:48 pm »
Drove it to Sureflo Exhaust this morning to install an X-pipe, 2.25 inch system from the headers with new mufflers, will hopefully have a nice neighbour friendly tone when I get it back.
Will post up some pics.
s
Offline moe
  • Name: "Moe"
« Reply #124 on: April 13, 2013, 07:33:57 pm »
took the seats out and stripped them down.  new covers go on tomorrow!
Also continued the radiator install and added some koni's to the rear.
Minor update - got them back today!
standard trim for the front and custom for the rear.  How ford should have done it:
