Hi All, I was just wondering if there is an easy way to get to the door switch? I have removed the kick panel, but there is no room there. I need to remove the bottom part of the dash and was hoping someone had some hints, otherwise it looks as if I need to work from the top down and didn't really want to pull out the instrument cluster if I could get away with it. The 69 has the foot/hand brake in the way, and it also has air con ducts. Any hints would be awesome. Thanks and Cheers.
