Just to clarify some issues, the donor Mustang diff was a 4 stud diff with a 3.20 CW & P. The tag indicates it is a 3.20 centre. It has been since successfully transplanted in the XP Ute diff which has the 5 stud wheels. The Borg Warner OZ CW & P are a direct copy of the Mustang 7.25 items. Bearings are the same , crush tube for the pinion is the same. Ford OZ just copied the yank specs. I now have a 5 stud diff which will bolt up with hardly a fuss. I plan to use the XP Ute springs also.
The XP Ute diff is different to the XP Falcon sedan diff in that the axle flange is larger in order to take the rear 10" drum brakes, and the axle bearings are larger/wider. Falcon sedans use 9" brakes on the rear and they are not interchangeable. The early Mustang 6 cyl diff has 9" drums but the axles are longer.
I am yet to finish the diff as I am obtaining XF rear brakes which will bolt straight up ( the brake shoes are the same as the XP Utes) I need to paint up the springs and obtain new suspension bushes for the rear.
Will let you know how it goes once I bolt it up. I am also installing front XY vented rotors on the XP Fairmont disc spindles ( same bearings as the XY) and will be using Girlock callipers from a WB Holden as they share the same bolt hole specs.
I have a second Ute diff which is the worse of the two that I obtained ( it had been drowned in a dam or flooded out) and I am just mucking around with it fitting XE rear rotors and callipers that bolt up. ( the calliper mount needs to be rotated 45 degrees to clear the springs. No drilling at this stage , everything just bolts up. ) Even the XF breather tube screws into the XP Ute axle, Ford changed nothing over the years.
XF brake shoes are the same as XP Ute shoes.
This Ute diff now has the Mustang centre and is painted. Awaiting the XF brakes.
That said, it would be a fairly simple process now to install 2.79 or 2.83 or 3.00 7.25" Mustang early centres for better cruising. ( if you could get them of course) It has been a great learning curve for me as I knew jack shizen about these diffs until I started pulling them apart and putting the verniers on the parts. There is a lot of Mustang DNA in the Falcon diffs.
XP Ute bearings were obtained from a local bearing shop and matched up to the Mustang bits perfectly.
