are you saying the dash lights are dim, if so the light switch itself will rotate to brighten or dim the dash lights. Be warned the original dash lights aren't very bright at best. If you ever take out the dash assembly, you can remove the little blue plastic lens from each globe holder & that will make the dash lights much brighter.........
