Author Topic:  (Read 3847 times)
Offline nassi
(No subject)
« on: October 10, 2005, 08:31:56 pm »
Is it possible that the fuel is vapourising? Try insulating the fuel line. When you switch off, the heat soaks through the spacer plate and boils the fuel in the bowl.
I suffered this at one point when the timing was retarded to much.
Just a couple of ideas, others will be able to help more.
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline ron
(No subject)
« Reply #1 on: October 17, 2005, 11:01:13 am »
If you're spinning and flooding,the mixture isn't getting lit,so your ignition system is a fault. If you have the GTR40 is the bypass circuit fitted(or working).A lot of people don't bother reconnecting this.Hope this helps. Ron
Money is made to be spent.
