upper and lower ball joints
Author Topic: upper and lower ball joints  (Read 1993 times)
Offline clintonjr79
« on: May 21, 2012, 10:28:56 pm »
does anyone know of a link or post in regards to replacing your upper and lower ball joints on a 65 mustang have the new ones to fit just want to know where to start.
« Reply #1 on: May 22, 2012, 08:44:50 am »
To be honest it is a bit of a job ,if they are original they are rivited in and you have to grind the rivits off and knock them out .If  they have been replaced they are bolted in and have to be knocked out .A ball joint seperator should be used,just go and have it done ,you will find it is a hard job if you dont know what you are doing .
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
« Reply #2 on: May 22, 2012, 09:07:59 am »
Usually why its cheaper and easier to choose complete arms, brand new.
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline unilec5544
  • Name: Neil.
« Reply #3 on: May 23, 2012, 08:23:49 pm »
from memory the upper are easy to replace, on my lower ones the ball joint plate was spot welded on as well, so clean them well to see the spot welds, which you will have to drill out. If I did it again i would buy complete units.
