My 50cent problem.
Author Topic: My 50cent problem.  (Read 3753 times)
Offline Ang1965
My 50cent problem.
« on: May 17, 2012, 11:59:28 am »
Hi All,
Lost lights on the instrument panel of my 65 coupe. Found a blown fuse. My initial response was "good that’s an easy fix", however i am struggling to find a 2.5amp fuse anywhere. have found on ebay but a little reluctent to pay $15 delivery from overseas for a simple little fuse. Anyone had the same problem and if so where can i get one locally (based in Sydney -West) ?
Offline Meaty0
My 50cent problem.
« Reply #1 on: May 17, 2012, 12:06:09 pm »
I too had a problem finding a correct 2.5 amp fuse.  I think I found the correct fuses at fuseco.com.au  (Had to buy 10 though).
If it's worth owning, it's had a song written about it.
Offline fordtj69
My 50cent problem.
« Reply #2 on: May 17, 2012, 12:08:25 pm »
hi ang57
try your local ? bursons they have good stock of spares or
try hills mustangs at seven hills micheal 0404187515
cheers tim
:drink:
                         BDCC
Offline Moz
My 50cent problem.
« Reply #3 on: May 17, 2012, 12:17:58 pm »
Why don't you get a 2.5amp Mini blade fuse and solder it to the old fuse
easy fix.
Moz  :cool:
Offline 66 Hertz
  • Web Editor
  • SA member #787 MOCSA
  • Name: Dale
My 50cent problem.
« Reply #4 on: May 17, 2012, 01:36:35 pm »
I did that......I folded the blade terminals over flat & soldered it to the old glass fuse......job done, also makes it easy to push in & pull back out.:thumb:
Paint by IMAGE CLASSIC CARS
Offline Ang1965
My 50cent problem.
« Reply #5 on: May 17, 2012, 02:03:03 pm »
Thanks for the tips guys. Ill drop a line to the places mentiond.
If all fails i love your idea Moz.
Hertz- just to clarify, did you solder the blade fuse onto the ends of the old dead fuse? Great idea, saves me pulling the fuse box out to solder..
Offline Moz
My 50cent problem.
« Reply #6 on: May 17, 2012, 02:23:43 pm »
Quote from: Ang57 link=topic=18007.msg179670#msg179670
That is correct
and it is easy to pull out holding the Blade fuse.
Moz:fantastic:
Offline Davet27
My 50cent problem.
« Reply #7 on: May 17, 2012, 02:59:40 pm »
If you have a Jaycar Electronics near you they stock 2A or  3A fuses. I would be comfortable going to a 3A, he'll I've used the foil out of a smoke pack when I was desperate.
My 50cent problem.
« Reply #8 on: May 17, 2012, 06:05:28 pm »
Most repco ,auto barn ,burson stores do carry them ,just tell them it s a old falcon ,if you say a mustang they will give you a dumb look .
Offline Macka
  • Vic member 1571
My 50cent problem.
« Reply #9 on: May 17, 2012, 06:24:08 pm »
TRy SuperCheap
