Hood mounted tach inaccuracy
Author Topic: Hood mounted tach inaccuracy  (Read 4131 times)
Offline 67FBGT
  • Car: 1967
« on: May 06, 2012, 12:27:12 pm »
Some years ago I purchased one of those repro hood tachs, a repro of those available after-market from way back around '69 or so. Subsequently I think the manufacturer has gone out of business.
It looks the goods, but reads high, consistently I would say around 50% high compared to the rev readings of both my  engine analysis tach & an in-dash tach which at least both agree.
Has anyone got any ideas as to why this might be & how I could correct it so it at least reads closer to reality? Am wondering if an in-line resister might be what's needed. Many thanks, John
Offline booah
« Reply #1 on: May 06, 2012, 02:09:39 pm »
Maybe the selector switch is set to a 4 cal, doubling the rpm output?
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
« Reply #2 on: May 06, 2012, 05:07:08 pm »
Quote from: booah link=topic=17916.msg178688#msg178688
If it works proportionately like you suggest, then if it's reading 50% high it'd be set to 6 cyl.?
Check to see if there's a switch for the no. of cylinders and set accordingly.
s
Offline bluestang
« Reply #3 on: May 06, 2012, 06:54:37 pm »
I put a hood mounted Tacho on and there was a switch to change it from 6 to 8 cylinder. I can not remember if the switch was in the guts and only accessed by taking it apart or accessed through the bottom of the casing. Mine reads true.
Offline bluestang
« Reply #4 on: May 06, 2012, 06:55:02 pm »
Offline 67FBGT
  • Car: 1967
« Reply #5 on: July 15, 2012, 08:37:30 am »
Thanks guys, there was a 3-way switch underneath that was mis-labelled but after a little experimentation the problem was solved. Cheers.
Offline mussy65
    • http://nsw.mustang.org.au
« Reply #6 on: July 15, 2012, 09:06:11 am »
Yet another correct diagnosis with corrective action provided ... in 90 minutes!
Well done brains trust.
Offline IGALOP
  • Pegasus
  • Car: 2017 GT
« Reply #7 on: July 15, 2012, 02:10:33 pm »
That's us, always on the ball and ready to remedy!:smile01:
Johnno;
Proud Vic MOCA member # 1569
Offline j1autotech
  • MOCA VIC member 1828
  • Name: Justin
« Reply #8 on: July 15, 2012, 08:27:27 pm »
Quote from: IGALOP link=topic=17916.msg184517#msg184517
Hmmm... how's the rust situation going on my car ? isn't it time for another wash :lol:
