Parts list copied below:
PARTS, PASSENGER MOTOR VEHICLE, manufactured at least 30 years
before the goods are entered for home consumption, or reproductions
of these parts, being ANY of the following:
(a) suspension components being ANY of the following:
(i) top or bottom control arms;
(ii) uprights, struts and wheel hubs;
(iii) anti sway bars and ball joints;
(iv) anti tramp bars and torsion bars;
(v) suspension bushes, links, bump stops and shackles;
(vi) wishbones and wishbone mountings;
(vii) bump stop spacers;
(viii) sway bar links;
(ix) suspension spring mounting plates and pads;
(b) brake and clutch bleeding nipples;
(c) hood retaining pins;
(d) chassis or monocoque;
(e) instrument and dashboard panels;
(f) radiator ducting (shrouds or cowlings);
(g) stub axles;
(h) fuel and oil tanks, fillers, necks and caps;
(i) roll over hoops or bars but NOT including roll cages;
(j) dipsticks;
(k) roll bar adjustment control levers;
(l) brake balance adjusters control levers;
(m) pedal mechanisms, pedal, pedal mountings, pedal stops, pedal
push rod;
(n) universal joints and constant velocity (CV) joints;
(o) chassis identity plates;
(p) steering idler arms and idler arm brackets;
(q) track rods and drop arms;
(r) steering link arms;
(s) steering box parts being ANY of the following:
(i) steering box housings and casings;
(ii) rocker shaft;
(iii) thrust buttons;
(iv) cover plate;
(v) filler plug;
(vi) shims;
(vii) rocker shaft bush;
(viii) steering rack mounting brackets;
(t) steering column surrounds, shrouds and facias;
(u) steering indicator turn off cam;
(v) differentials;
(w) differential components being ANY of the following:
(i) differential carriers and cases;
(ii) crown wheels and pinions;
(iii) differential and axle shaft gears;
(iv) differential lockers;
(v) bearing caps, locking pins and locking clips;
(x) transmission shafts, including propeller and half shafts,
transmission gears and transmission housings (casings), gear
selection mechanisms, gear levers and gear change rod;
(y) gearbox parts being ANY of the following:
(i) selector forks, sleeves, detents, and housing plates
(ii) gearbox filler plug and reverse gear relay lever;
(iii) gearbox housings and interlock plunges;
(iv) clutch release arms;
(v) synchromesh rings and counter shafts;
(vi) blocker rings;
(vii) retaining clips;
(viii) sandwich plates;
(ix) speedometer driving gear;
(x) spacers;
(xi) bearing carriers;
(xii) locating ball;
(xiii) countershaft and countershaft gear;
(xiv) reverse idler shafts and synchronisers;
(xv) baulk rings;
(z) dust seals and cabin fume excluders;
(aa) pipejunctions;
(ab) exhaust mounting brackets, plates, ribs and pipe straps;
(ac) gearbox tie down straps;
(ad) ornamental trimmings or fixtures;
(ae) number plates and number plate bezels and trims;
(af) interior trim, cut to fit;
(ag) interior and exterior mouldings;
(ah) dashboard, instrument, console and speaker bezels;
(ai) ornaments proclaiming the make, model, style or accessory
level of a vehicle;
(aj) air ductings;
(ak) flexible cabriolet hoods;
(al) chassis reinforcing mountings;
(am) inner wing reinforcement;
(an) door striker plates, door blanking plates and footrests;
(ao) handbrake levers and handbrake lever mechanisms;
(ap) cables;
(aq) aeroscreens;
(ar) ashtrays and gloveboxes;
(as) door filler strips;
(at) door window glass runners and guides;
(au) window winder mechanisms;
(av) side panel crash rail;
(aw) door kick plates and panels, heel boards;
(ax) panel release clips;
(ay) fan blades;
(az) sun visors, sun visor mountings and brackets;
(ba) flexible boots (commonly known as gaiters or bellows);
(bb) consoles, placed between the driver and front seat
passengers;
(bc) header rails;
(bd) control knobs, layers, buttons and panels;
(be) choke and accelerator cable stops;
(bf) heater;
(bg) heater facia panels;
(bh) grease caps;
(bi) steering wheel bosses;
(bj) moulding and trim beading strips;
(bk) reinforcing plates;
(bl) fuel pumps;
(bm) door pulls;
(bn) kingpins;
(bo) tonneau pegs;
(bp) radiator header tanks, diaphragms and cores;
(bq) head rests
