Electronic ignition for a 1970 mach 1
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Technical - General
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Electronic ignition for a 1970 mach 1 (Read 1880 times)
ty351
P Plates
ty351
on:
March 31, 2012, 03:23:52 pm »
Hi everybody, I have a question. I have installed a MSD electronic ignition system and was wondering if my car has a ballist resistor or not as it had points on it when I bought it, if so where would it likely to be found.
Thanks Tyrone
Logged
Frank70
Supercharged
Frank70
Reply #1 on:
March 31, 2012, 03:28:58 pm »
Hi Tyrone.
yes your car will have the resistor.
there should be a pink resistor wire between the ignition switch and the coil. easiest thing to do is bypass that wire with a wire going between your ignition and connecting it to the green/red stripe wire at the ignition switch.
Frank.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Technical - General
