Hay chopmgw
Love the colour of your car
:hammer:
Spent the day pulling the interior apart to remove the seat belts, head lights and radio, removed the rear drums and inspected the undercarriage and engine bay.
So here’s my list of things to do nothing real drastic what’s so ever.
• Both rear brake cylinders need replacing
• Brake line from body to dif needs replacing
• Front sway bar bushes need replacement - full set
• Power steering unit needs attention including hoses - likely rebuild
• Fuel line needs affixing to body as most of the rear section is floating
• Fuel tank drain plug leaking
• Removal of rear sway bar - Regency
• Replace chrome water pump with std cast unit - Regency
• Remove Alpine stereo with period correct radio - Regency
• Replace all seat belts - Regency
• Replace head lights - Regency
• Oil and filter change
• Flush out old brake fluid
• Flush out radiator
• Adjust passenger window seal as door does not close properly when window all the way up
• Refit rubber cover on clutch pedal
• Inspect spark plugs (sounds simple anyone with a FE motor will know why it’s not)
• Test HT leads
• Brake warning light staying on (no doubt related to rear wheel cylinders)
If anyone can recommend where I can get the power steering rebuilt please let me know along with where best to purchase the brake components would be much appreciated it does not have to be in Adelaide anywhere in Australia.
Nice car!! and great color combo!!! Good to see another C/Jet in SA.
Barry knows his stuff and helped out big time with my questions!!
Power brakes in Adelaide is where I got all my C/Jet brake bits from. They even rebuilt my calipers for me.
To do the plugs!! Take the tappet covers off. Pretty easy to get at the plugs then. Seems like a lot of work but once off, it does not take long.
I would leave the rear sway bar on and see how you go.
Just remove the radio for inspection. Hole in dash is acceptable
Window will never seal properly, I just leave mone down a few mm and the door closes and seals fine
Brake warning light, on dash?? would be hooked to park brake. If you mean rear brake lights? yes it will be the pin in the m/cylinder needs centering when you bleed the brakes.
good luck!!
Oh, and 2 welsh plugs of the appropriate size with a few 8mm holes drilled in them, and slipped into the tail pipes will save you the expense of new mufflers:thumb:
