lead filler v's current products
Author Topic: lead filler v's current products  (Read 4086 times)
Offline andy72
« on: February 08, 2012, 06:11:45 pm »
Just getting some thoughts on which is best for filling the rear quarter and roof join..and if its lead  whos the guy to do it...in VIC
A spade is a spade life is life, be who you are despite all let the deck fall as it may
Offline Frank70
« Reply #1 on: February 08, 2012, 08:00:14 pm »
I guess if you want originality then lead is the go.
Altho putty will do the job no doubt.
These guys used to do the segments on Gasolene :
Peach&Tomassini
Peter Tomassini has a shop now, not sure what happened to Peach.
Tomassini Restos
Frank
Offline evan
« Reply #2 on: February 08, 2012, 08:40:22 pm »
Dunno how true this is but I've heard people say that lead is less flexible than filler & more likely to crack. Peronally, I left the lead in mine because there was nothing wrong with it.
Evan.
Offline SXTY8
« Reply #3 on: February 08, 2012, 09:14:33 pm »
I believe the plastic fillers of today are far superior to the lead filler that was used in the past.
If it's properly applied it will last the life of the car.
I think it gets a bad rep from all the half arsed amateur jobs that you see on the road.
If you watch some of the American car shows, you see them cover the whole car in a skim of bog, then sand most of it off to achieve a perfect panel.
