gt40p heads in a 66 engine bay..
Author Topic: gt40p heads in a 66 engine bay..  (Read 4103 times)
Offline Bashfull
« on: February 03, 2012, 09:22:43 pm »
ok...what exhausts work and fit well...
do k- code manifolds work
do mac shorties fit into the engine bay...?
Offline tq1
« Reply #1 on: February 08, 2012, 09:32:21 pm »
I have these heads on my 351/ windsor  in my 67. I gave a gasket to a mate who had access to a plasma cutter. He made two 16 mm flanges and i used a set of pacemaker headers off the shelf. Works out a lot cheaper than custom headers. Having said all that i just received my starter motor and it does not  fit
I will have to modify slightly .  :cry:
Offline ASE TECH WENCHWRENCHER
« Reply #2 on: February 25, 2012, 04:05:17 pm »
HEY TQ, WHAT ENGINE BLOCK ARE YOU USING? CHECK YOUR SPLINE/TEETH NUMBER FOR PROPER STARTER FIT... EXAMPLE- A 53 SPLINE STARTER WON'T FIT A 58 SPLINE/TOOTH FLEXPLATE... ARE YOU USING A 4- SPEED TRANS OR AN AUTO MATIC? IS IT A C-4 OR A C-6? ALL OF THIS WILL MATTER FOR CORRECT SPLINE/TOOTH MATCH... CINDY ASE TECH USA[ CERTIFIED IN TRANSMISSION R&R IN THE USA
