Hot off the press, I got this from Schumacher:
Rules and Regulations for exporting vehicles to Australia with A/C unitsAir conditioning gasses and systems come under the control of the Australian Department of Environment and Heritage, and those fitted to vehicles/trailers fall under very strictly controls. This is a technical area of the import process but the department have not issued specific forms to enable compliance, only a set of guidelines, as follows:
• If the car is not fitted with air conditioning a certificate from the shipper of the car to state the car is not fitted with air conditioning is required.
• If the car is fitted with a CFC air conditioning system the whole system MUST be completely removed before shipment. CFC units are strictly prohibited. Alternatively it can be converted to HCFC before shipment but a certificate from a certified air conditioning engineer MUST be supplied – see below
• HCFC air conditioning units MUST be degassed with the dryer and Schreader valve removed by a certified engineer. The engineer must supply a certificate on their business letterhead to state that all gas has been removed (it MUST also name the type of gas) and that the Schreader valve and the dryer are removed.
• An old system which has been removed from the car and is placed in the trunk of the car is NOT allowed without a certificate as it could be a CFC system and therefore prohibited.
• Units cannot be removed or degassed after the car arrives in Australia. Should a car arrive without acceptable certification the costs and repercussions can be devastating.
As a service to our clients, we can have the existing CFC unit Degassed and the Schreader valve disconnected for $250.00.
This will also include a letter of certification from a qualified engineer which will be sent along with the necessary paperwork to the receiving agent in Australia for customs clearance.
Air conditioning systems and their certification, is becoming more and more of a challenge for exporting cars and now ranks as important as the Import Permit for the car. For more information call us on 562 408 6677 and/or visit:
http://www.environment.gov.au/atmosphere/ozone/licences/index.htmls
