wire running along LH top of engine?? 66 289
Author Topic: wire running along LH top of engine?? 66 289  (Read 3153 times)
Offline mattp
« on: December 21, 2011, 07:19:57 pm »
Hi I have just found a wire running along the top of the inlet manifold on the LH side. It was just hanging free. It has a tag on it as if it slides over a sender unit. I put my test light on it with ignition on and it pulses current....any idea where it goes?
Thanks:feedback:
Offline Macka
  • Vic member 1571
« Reply #1 on: December 21, 2011, 07:33:55 pm »
Electric choke wire?
Offline mattp
« Reply #2 on: December 21, 2011, 07:38:30 pm »
Hmmm, nup dont think so, it comes out of the standard loom and looks to be yellow, before someone attached a red section to it. It has an Edelbrock carb with lecky choke by the looks all connected ok. I have not had the car long, so I am still getting familiar with it.
Offline 6508k
« Reply #3 on: December 21, 2011, 09:18:03 pm »
One wire goes to temp sender unit on intake manifold and other wire goes to Oil pressure sender unit on engine block.
Offline skev
« Reply #4 on: December 22, 2011, 08:40:05 am »
Yep, if it's pulsing its almost definitely coming off the voltage regulator. Do you have a non functioning gauge?
67 Convertible
Offline mattp
« Reply #5 on: December 23, 2011, 05:08:11 pm »
Ahhhh, Thanks Guys! Correct, Gauge is not working. I can see the one to the temp sender, i will try and locate the oil pressure sender.
Thanks again!!
Offline skev
« Reply #6 on: December 23, 2011, 07:57:01 pm »
Lh side, down in front of your oil filter, about the size of q cotton rel
67 Convertible
Offline mattp
« Reply #7 on: December 27, 2011, 09:53:15 am »
Thanks again!:thumb:
