Clutch cable to firewall entry point
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque 1979 to 2014
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Clutch cable to firewall entry point (Read 4323 times)
ray_aus
Pony
ray_aus
on:
September 19, 2011, 09:45:56 am »
I need to know if anyone with a 2001 cobra has a teflon spacer between the end of the clutch cable and the firewall as my clutch is gripping on the top of the release and I am not sure if this was placed as a after market item
It is the white teflon as seen on the image attached.
Thanks in advance.
Logged
66 Hertz
Web Editor
Top Streeter
SA member #787 MOCSA
66 Hertz
Reply #1 on:
September 19, 2011, 10:17:44 am »
no image?..........:banghead:
Logged
Paint by IMAGE CLASSIC CARS
build thread...
http://www.mustang.org.au/forum/index.php/topic,14043.0.html
jiffy
Supercharged
jiffy
Reply #2 on:
September 20, 2011, 12:06:33 pm »
Yup, sure has - the end of the black cable fits into it and then the white part goes through the firewall.
Having problems with your clutch? - having the same issue with my 2002 Cobra, happy to talk...
Logged
jiffy
Supercharged
jiffy
Reply #3 on:
September 29, 2011, 01:37:43 pm »
Try taking the split pin out of the shaft the cable U-clip sits on. It rests on two little yellow bushes.
REmove them all, grease the shaft and reassemble - see if that's any better.
Get a can of WD-40 with the little red tube that allows you to spraya small surface at a distance. Spray the end of the cable where it goes into teh sheath through the firewall - see if either of these improve the movement....
Logged
Print
Pages: [
1
Go Up
« previous
next »
