Bluediscus84, if you are buying the car in NSW to bring to Victoria to register, dont worry about pink, blue or green slips as they only apply for registeration in NSW, you will need the import approval and bill of sale. Then you just get a normal roadworthy certificate done on the car by your local mechanic (or some one recomended in your area), as long as it passes the roadworthy,(if not get the offending problems fixed) and then front up to Vic roads and get it registered. You could ask the seller to get it registered as part of the sale but the rego will only be current for NSW and you will still have to get a roadworthy certificate to change it to Vic rego hope this helps cheers Adam
