mini tub
Author Topic: mini tub  (Read 4599 times)
Offline tq1
mini tub
« on: January 15, 2011, 12:05:18 pm »
:dHI i have completed mini tub on 67 F/B leaf springs diff all standard.Have gained 30mm has my b/spacing changed and how do i measure for max rims.Wanted 17/8 & 17/10 rear.:feedback:
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
mini tub
« Reply #1 on: January 15, 2011, 12:09:24 pm »
Hi, so did you move the leafs inboard, or did you just square up the tubs, and cut into the rail? Or did you not cut into the rail?
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline tq1
mini tub
« Reply #2 on: January 15, 2011, 12:33:22 pm »
BLKPNY have not altered anything else.Just added 30mm to inside of tub making it flush with rail.
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
mini tub
« Reply #3 on: January 15, 2011, 12:45:02 pm »
Do you have a selection of 17" rims/tyres to try on?
I'd try to fit a 17x8 AU onwards rim, to see how much space you have inside the well, and a 17x8 pre AU rim, to make sure it fits on the outside of the well, then, if there is a little more room, add it in to the combined size.
Just making figures up here, but a 8" rim is 9" wide, with the bead added in. Add a tyre, maybe 1 more inch. So a 17x8 should be about 10" wide sidewall to sidewall. So your 10" rim will be 12" wide all up.
If a pre AU rim has 4.5" bs (dead center) and an AU onwards rim is 6" BS, then you have 1.5" difference.
So if a AU rim fits, with an easy 1/2" more room on the inside, and a Pre AU rim fits OK on the outer, you've found the extra 2" you need. So you would need a 6.5" BS 10" rim, to be the same.
Backspacing and front spacing, MUST equal 1" more than the advertised rim size. So a 8" rim, with 4.5" BS, MUST have approx 4.5" front spacing.
Custom Mustangs
Signature Sponsor
Offline tq1
mini tub
« Reply #4 on: January 15, 2011, 12:58:59 pm »
Thanks BLKPNY .Motorvation show on today in perth may be worth a wander down there.Some kind sole may be able to lend me some rims to try.:violin:
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
mini tub
« Reply #5 on: January 15, 2011, 01:09:07 pm »
Surely you know someone with a Falcon, on 17's? EA onwards, most have them by now, even the EF, AU & BA's ran them standard. Just borrow their spare, if they have a full size spare.
Custom Mustangs
Signature Sponsor
Offline 6T9rustang
mini tub
« Reply #6 on: January 18, 2011, 09:35:53 am »
Here is a helpful link for getting backspacing measurements:
 http://www.getahelmet.com/jeeps/tech/backspace/
Once you have determined the backspacing of the rim you have, THEN add the distance from the back edge of that rim  to the leaf spring edge to get a total. BUT as mentioned by BLKPNY, you must take into consideration tyre sidewall or bulge which will be an inch more to the total.
I too have mini tubbed my '69 but I have changed my leaf springs for control arms(three-link suspension) which allows for even more backspacing.  I have 18x11 rims with 6.25inch backspace. :comp:
