Hi all,
Hope someone can help me out here. My rear left indicator and brake light work ok, however on the rear right, no indicator or brake light work.
I have troubleshooted and here is what I have come up with so far.
When headlight are on, rear tail lights are fine.
Front indicators work - no problem
Dash indicators work - no problem
When hazards are on, only left side flashes.
There is no voltage to the rear right lens through the orange blue wire.
From the steering column, the two wires leading from the indicator switch, ie one orange and one green - only the green one (ie. left hand side) one is live and flashes with a 12V testing light, the other that goes to the right has no voltage again.
Has anyone experienced this? Is it likely to be the indicator switch in the steering column? This is only 1 year old and have had no problems until a few weeks ago.
If it is the indicator switch, how is it that the hazard lights are also affected?
Also if it is the indicator switch, how is it that the brake light won't work?
Sorry about the long post, but I want to give as much details as possible.
Regards
pbapam
