Mustang Explodes On Dyno.
Author Topic: Mustang Explodes On Dyno.  (Read 6536 times)
CPU
  • Guest
CPU
« on: December 15, 2010, 03:48:47 pm »
OOPPSS!
[youtube]NO5z9XLz1AM[/youtube]
Offline Macka
  • Vic member 1571
« Reply #1 on: December 15, 2010, 03:54:22 pm »
Why oh why do these dyno blokes think that they can just keep reving the engine well past the shift light extremes?
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
« Reply #2 on: December 15, 2010, 07:25:13 pm »
I got a vid om my brothers Mustang exploding at Calder.....
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline IGALOP
  • Pegasus
  • Car: 2017 GT
« Reply #3 on: December 15, 2010, 07:42:26 pm »
Ouch, what's that expensive noise I hear?
Johnno;
Proud Vic MOCA member # 1569
CPU
  • Guest
CPU
« Reply #4 on: December 15, 2010, 07:48:13 pm »
Quote from: BLKPNY link=topic=13117.msg136223#msg136223
How big is the file size of the video?
We can send you a link to a service that we are licenced with.  It allows you to upload the file and then we can down load it from the server.  We will re-size it if necessary, put it up on YouTube and display it hear.  If you want to. :hi:
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #5 on: December 15, 2010, 08:03:19 pm »
Here is a link, we are the car in the opposite lane.
Everyone was videoing the Cortina, as it is a mid 9 second streeter, with a huge hit of gas, and bad start line manners....
http://www.youtube.com/watch?v=OUXA8QmV864
[youtube]OUXA8QmV864[/youtube]
YouTube Video inserted
CPU
Custom Mustangs
Signature Sponsor
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #6 on: December 15, 2010, 08:14:09 pm »
And another angle...
http://www.youtube.com/watch?v=OtQdjDsc2_c
[youtube]OtQdjDsc2_c[/youtube]
Custom Mustangs
Signature Sponsor
Offline Dad
« Reply #7 on: December 15, 2010, 08:25:25 pm »
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$:cry:
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #8 on: December 15, 2010, 08:29:08 pm »
Cheers mate....
For those wanting to know what happened...
There is a shaft which drives the oil pump on the transmission, which broke. What happens then, was the back of the convertor is slowed down by the transmission, while the engine, making about 1000 - 1200hp, basicly twitsed the front off the convertor (like opening a new bottle of Coke). The pieces of the convertor (doing 8000rpm) went straight thru the SFI rated bellhousing (which is meant to be a rated shield).
The huge puff of smoke is actually a misty cloud of extremely hot transmission fluid. Once there was no driveline connected, the engine free-revved, and hung on the limiter. The resulting backfiring out the pipe then set fire to the highly volatile cloud, resulting in the fireball.
The transmission extension housing broke, so there was nothing but the output shaft sitting over the crossmember and the shifter cable holding the box in, luckily the car didn't run it over, and just dragged it down the track, wearing away the alloy sump.
Shrapnel put dents in the front guard (from the inside!) and put a couple of holes in the floor, in the passenger footwell. They were still so hot, they then set fire to the carpet.
The fireball burnt away the parachute, and melted the rear bumper and taillights. It also destroyed all the braided hoses under the car, fuel, trans cooler etc etc.
We are told there was a 6" wide, 4" deep hole in the track, from the explosion.
Driver was OK at the time, he was a little surprised at the reaction from the safety crew, as he didn't see too much from his position, but after seeing the car, and the vid's, he was shaken up for a few days!!
Custom Mustangs
Signature Sponsor
CPU
  • Guest
CPU
« Reply #9 on: December 15, 2010, 08:56:00 pm »
:omg: :thud:
He's lucky he didn't get hurt.
That Corgy is one wild ride.
CPU
  • Guest
CPU
« Reply #10 on: December 16, 2010, 12:51:50 am »
Ok I know it's not a Mustang, but Damm. Makes you think twice about putting your pride and joy on a Dyno
[youtube]oKFGr_mkQaA[/youtube]
Offline 65muzzy
« Reply #11 on: December 16, 2010, 05:23:55 pm »
Cortina needs some serious rear end work.  Can't see how it runs 9's by launching like that.  Friends cortina had 4 link plus other modes done to get it to run straight.  Even with that it still runs down the track with a slight lean to one side.
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #12 on: December 16, 2010, 06:02:04 pm »
It ran 9's with 200 of gas, and launched pretty nicely. 300 shot made it a completely different car. It still ran high 9's like that. It's the same guy that owned the old purple gasdup corty, which ran high 8's, and the new psidup silver corty thats running high 7's,while still being sorted.
Custom Mustangs
Signature Sponsor
Offline jas24zzk
« Reply #13 on: January 05, 2011, 10:11:28 pm »
Quote from: Macka link=topic=13117.msg136201#msg136201
Looking at that, it actually popped the turbo when he lifted the foot, its a split second later.  Quite common on turbo's for some reason beyond my knowledge.
But going with your theme, those guy look like meatheads anyway....note guy sitting in the boot to assist with traction hold down.  Only reason he is more usefull than a cement bag is he is self moving....
:lol:
Offline jas24zzk
« Reply #14 on: January 05, 2011, 10:13:19 pm »
Quote from: CPU link=topic=13117.msg136264#msg136264
Any dope knows 4wd dyno, 4wd car needs side restraint on the front!
more yanks?  :smile01:
