From
http://www.bob2000.com/carb.htm[align=center]
Common Problems
Lots of folks have been emailing me with some common problems, so here are some tips for fixing these common problems.
[/align]
Gas is flowing out of places it shouldn't.
This is most likely due to a bad float valve, bad float, or excessive fuel pressure. The first step is to check the fuel pressure, which should be between 4 psi and 7 psi. If the fuel pressure is correct (or you have no reason to believe that it has changed on an existing setup such as an old stock mechanical pump), either the float has sunk, or there is a problem with a float valve. ................I had this problem decades ago. Old rubber debris was getting stuck on and off in the needle and seat of the float of a new Holley and either the engine would die from lack of fuel or it would overflow (flood).
Cause: When the carby was changed the old fuel lines were disturbed and bits of rubber moved through the old fuel lines and into the carby.
Remedy: Pulled carby down, removed needles and cleaned out seats. Replaced fuel lines and flushed system. Inserted fuel filter next to carby. (I was always taught to NEVER EVER put a fuel filter on the suction side of a fuel pump. This is a topic for another discussion)
Don't know what model you have but
HERE is the tech sheet from Holley on the MODEL 4150 ULTRA HP SERIES.
{P/N 0-80674 (650 cfm), 0-80675 (750 cfm), 0-80676 (950 cfm)}
Might be something else is your problem but thought this may help
Kind Regards
CPU
PS
Sintered bronze fuel filter inserts are almost a must with Holleys.
[img=700x525]http://i24.photobucket.com/albums/c17/CFrance/IMG_0044.jpg[/img]
I'm not a qualified mechanic. Above comments are only from my own observations and information gathered from the net.
CPU
