Apart from a Compact Fairlane which is what ford used, there are no links that work correctly, you cant jsut turn a mustang one backward etc. You have mod a falcon one. Oz falcons are wider than a Mustang. the link shape on 67 + car is similar to an XY, but shorter by about 23mm. But pre 67 cars are very different, due where the tie rods mounts. The only way is cut shut, xray. If you want it correct that is. Even the Oz compact Fairlane is only just ok.
Start with and XY and XY idler and go from there.
