H4 Headlight & H3 Fog Light Lens's, Angel Eye, Projector, Crystal, Regular etc etc
Author Topic: H4 Headlight & H3 Fog Light Lens's, Angel Eye, Projector, Crystal, Regular etc etc  (Read 10568 times)
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
I've just had a huge delivery come in.
Semi Sealed beams for all Mustangs from 64-73 (except 69 and some Eleanor).
White LED Angel Eye $135 Pair
Crystal Headlight $75 Pair (Has provision for Parker Bulb, if you require).
Crystal Headlights with Projector (Magnified) $100 Pair (Has provision for Parker Bulb, if required)
Regular Style, Wide angle, for better visibility $75 Pair, with provision for Parker Bulb if required.
We have bulbs for these, from 55/60w (Max Legal), 90/100w and 100/130w.
We also sell QUALITY HID kits, in a Hi/Lo setup, to fit our lights, or any H4 setup. These are a proper Plug & Play kit, no extra looms to wire in, etc etc. They are White in colour (We rate them as 4300K, but everyone measures it different, I've seen blue 6000k, and white 6000k, we found these kits at 4300k to be white). 35w will take a lot of load off your aging electrical systems. These are much brighter than regular bulbs, and nearly half the wattage. Not always legal in all states, please check if you are concerned.
We got into HID kits, after buying a set of Jaycar HID's, and having a ballast die on our 3rd drive since fitting them. Experience with other cheap Ebay kits has always shown the Ballasts to be the weak point, on the crappier kits.
We also have a H3 Fog light bulb insert, for 64-68 Foglights. Looks very similar to original lenses, and can be fitted with 55w, 100w or 130w bulbs $85 Pair
We can supply HID kits for these, with slimline Ballasts.
We have also had a delivery of Genuine GE fog light sealed beams. These have the Fog on the lens. $60 Pair (available individually, $32 each)
For those interested, we also have:
5x7" Rectangles, for cars like F100, Bronco, Holden Rodeo, Hilux, etcetc, in Crystal or Angel Eye
4x6" Rectangles for cars like Chev Trucks, Toyota 61, 62 or 80 Series Landcruiser, and Hino, Mitsubishi, Dyna and a few other trucks. We have these as crystal inners and outers, and outer Angel Eyes (Outers can be used as inners)
We are also looking at getting some 7" with a curved lens, but that will be some time away (we have a 20' container to go thru first!).
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline LEE H 69
Hi Steph
Are those Angel eye lights available in the smaller size for the 69's, I'm sure I've seen a photo of them on one, if so I might be interested.
cheers
Lee
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
I knew this would happen!
Our first delivery only had a couple boxes of regular style lights, to suit 69's, and I have only 1 pair left.
Our next order will be in a couple months, and I am thinking of getting them, but I need to know they will move, as I need to commit to a thousand of them....
Oh yeah, I forgot, delivery to most cities, $12 pair.
Custom Mustangs
Signature Sponsor
Offline LEE H 69
I was thinking if both pairs are available (ie High beam lights in grill also) or would both sets have high and low beam ?
 I might get two pairs
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
We do this in 80 Series cruisers, and early chevy's, with the quad lights.
You put 4 of the hi/lo outers in, and the inner only uses 1 of the filaments of the H4, or, you can jump a wire from the hi beam inner to the spare filament, so on lo beam, you have the outer lo beams on, and hi beam, you have 2 lo, and 2 hi beams on, each side! Looots of light!
It would be a similar thing with these. Would look pretty sinister, parked in a dark parking lot, at night, with the parker lights on....
The top pic in this thread, is our lights in a mates GQ nissan Patrol.
Custom Mustangs
Signature Sponsor
Offline LEE H 69
Thanks Steph
I like the sound of all four hi & low beam, should look coool
keep me in mind if you do decide to go ahead and order some in as I will have 2 pairs:rub:
Offline 69ISH
  • Name: Rodney
Hi Steph,
I will take 2 pair as above as well if you order them in.
Cheers Rodney
1972 Gran Torino Sport (Sold)
1968 Mustang Coupe (Sold)
Offline Envy 68
Do I need to add a relay set up with any of these?
SALUTE!!  To those who have given their lives doing their job.
Offline boss 427
When you get the white led angel eye for a '69 I will take a set of 4. Thank you.
Gordon
Offline LEE H 69
 Eh Steph
Looks like it's getting closer to making an order for the 69 boys!
The wife did wonder what to get me for christmas:smile01:
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
Yeah, looking like that!
I should have an answer soon...
Custom Mustangs
Signature Sponsor
Offline 6T9rustang
Does the stainless steel ring fit around the lenses for the 69? I have purchased a different brand from a different company and have this problem of the ring being too small for the lenses. :feedback:
Offline stangLover
Do you have something for 'Eleanor'?
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
Bas, are yours 5 3/4" or the original 7"? I've seen Eleanors with either.
6T9, get me the inside size of your rings, and the outside size of the headlights (where the ring goes) and I will check the pair of regular ones I have here.
I've sold a few hundred of the 7" ones, without any issue with fitment, and I supply the Mustang rings to people who need them, and they've fitted every application so far (Toyota, Nissan, Trucks etc etc) as they are a standard size.
Custom Mustangs
Signature Sponsor
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
Ok, 6T9 won't be near his car for a couple weeks, if anyone has a 69 headlight mounting ring, can they measure the inside, to check against the light I have here?
Custom Mustangs
Signature Sponsor
Offline LEE H 69
If I get chance I'll measure mine tommorrow for you
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
cheers mate
Custom Mustangs
Signature Sponsor
Offline boss 427
Quote from: BLKPNY link=topic=12181.msg134239#msg134239
5 11/16" id on '69 light ring
gordon
Offline LEE H 69
well that saved me a job this avo:cool:
Offline 69ISH
  • Name: Rodney
Quote from: boss 427 link=topic=12181.msg134339#msg134339
gordon
On the headlight side of the ring the id is 5 3/4"
see the second photo
N.B. I started my measurements at the 2"mark as to get a more accurate measurement.
Cheers Rodney
Offline 6T9rustang
Conversion : 5 11/16in = 5.687 5 inch = 144.462 millimeter
Conversion : 5 3/4in = 5.75 inch = 146.05 millimeter
Offline Tempest
Steph,
I'm interested in 4 to suit a 69 too.
i'd actually prefer the crystal headlights to suit 69
Gary
