I too am going to have to get either a new dizzy or a new ignitor box in the electronic dizzy I have. The previous owner said that the ignitor box in the dizzy can sometimes go dead if it gets too hot. Whats the difference between the 1281 version and the 1281DV version? I think the 1281DV version is for a dual point dizzy.http://www.jegs.com/p/Pertronix/Pertronix-Ignitor-Kits/746414/10002/-1?itemPerPage=60&pno=1
Are you stalking me barnett468?
I fitted the 65-73 MUSTANG & FORD PERTRONIX V-8 IGNITION KIT 1281 to my car on friday night. It was as simple as remove the air cleaner, unclip the distributor cap. Pull off the rotor button, unscrew the points & condensor, take off the wire to the coil. Press on the plastic sleeve onto the distributor shaft, screw down the new Pertronix unit where the points was, set the air gap with plastic gauge supplied, refit rotor button & cap & air cleaner assy. Connect the two wires to the coil.....Job done in under 5 mins.checked the timing & was spot on still.....fired up instantly, put over 300 miles on it over the weekend..........two thumbs up..
