L300 Front end for 67 Big Block
Author Topic: L300 Front end for 67 Big Block  (Read 8460 times)
Offline GOLDSCODE
« on: June 25, 2010, 10:52:55 am »
ShaunP suggested the L300 front end instead of the Mustang ll front end, seems like a good way to get more room in the engine bay of my 67, ie delete the shock towers, l fully intend on a right hook conversion, correct me if lm wrong but L300 seems like a  good way to go,
whats your thoughts ??
                         cheers Ralph:feedback:
« Reply #1 on: June 25, 2010, 11:12:37 am »
Cheap, anyway if you can make it work ! I'd just buy one and see how it looks. The Rod boys mod them a bit, wouldn't be hard to find out what they do, I know guys with a couple in rods I could look at.
Offline GOLDSCODE
« Reply #2 on: June 25, 2010, 11:27:55 am »
Thanks Shaun, My car will be more Restomod, than origional, just thought it looked a pretty clever way to achieve two things at once, ie Rhd and more space for decent pipes a cleaner engine bay and no hassle plug changes on a 390, im sure if you get over the fact its Jap gear and its a clean install, its all about building a better mouse trap,
cheers Ralph
Offline FST68
« Reply #3 on: June 25, 2010, 12:56:27 pm »
I like the concept but there is likely to be a fair bit of mods to make it work.
If it was me I would spend the extra money and use something that has aready been sorted.
Offline HEVEN67
« Reply #4 on: June 30, 2010, 10:06:03 pm »
Flaming river or somthing similar, L300 front end may be a little heavy, hey try a drop axle!
Offline GOLDSCODE
« Reply #5 on: July 22, 2010, 01:47:03 pm »
Now theres a thought Hev 67 fastback Gasser !! like the old stickers you used to get when Ratfink had his hand on the shifter poking through the roof!!! great memory thanks !! :thumb:
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
« Reply #6 on: July 22, 2010, 01:54:06 pm »
There was a 66 in street machine recently, with a Torana rack in it, setup by Taverna Chassis, maybe they've done others.
Setting up the steering for RHD is the easy bit, anyway. The harder part is the firewall and dash.
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline HEVEN67
« Reply #7 on: July 24, 2010, 04:53:25 pm »
OR jag front end, they are rack and pinion standard, Im not sure about the width though!
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #8 on: July 24, 2010, 05:12:29 pm »
A mate is fitting a Jag front to his Customline, so they obviously can handle the weight.
Custom Mustangs
Signature Sponsor
Offline jas24zzk
« Reply #9 on: August 05, 2010, 11:52:55 pm »
I have a 63 Falcon XL ute project.  Originally I had the grandiose idea of fitting an 4.0 Turbo to it, shock tower delete using either the L300 or mustang 2 front end.
I did some research and found the M2 front end a much easier fit, with minimal difference in rail width (20 mm to be exact :smile01: )
I'm not sure, but i can check easily enough, but i think that the muzzy is wide enough to accomodate the M2 front end with no major surgery.
Where you may run into problems, is if you attempt a 100% delete of the towers. As you will be removing a lot of strength that has to be made up somewhere else.  However, if you retain the original top to accomdate an export brace, you can get pretty wild in the trim on the towers.
The major thing that swayed me to the M2 option, was the wide range of readily available parts.
As for the Rack, there are plenty of guys that have converted Mustang 2's about, a simple chat with one of them would tell you what to use, failing that most of the manual racks from the states can be flipped with minor alterations.
The kits out there to fit an M2 front end make it easy...someone else has already reinvented the wheel for you.
Jas
Offline GOLDSCODE
« Reply #10 on: August 06, 2010, 04:17:35 pm »
Intresting thanks Jas :thumb:
« Reply #11 on: August 12, 2010, 09:23:09 am »
Quote from: jas24zzk link=topic=11150.msg124485#msg124485
Jas
I think mustang 2 and fox body racks just turn up upside down.
