AOD
Author Topic: AOD  (Read 10330 times)
Offline derwin66
AOD
« on: June 23, 2010, 09:15:09 am »
People is there a Australian AOD geabox that can be used on a 302W for a 65 mustang that does not involve tunnel work.  I don't want to have to get one from the states. and sorting out which would be a better option AOD unit or a gear vendors
65 T code coupe.
Blown 302. Heidts suspension, tricked C4
Gear vendors overdrive, RRS rack and pinion
Street or track roller perches adjustable struts.
60 F100.
Warm 289, AOD
Offline scott66stang
  • Account Suspended
    • http://www.mustang.org.au/forum/viewthread.php?tid=6440&page=1
AOD
« Reply #1 on: June 23, 2010, 10:12:56 am »
No Ozzie Ford came out with  the AOD , so the states is your only option . Dont know about the tunnel mods , i have used a 94 Fairlane electronic 4 speed auto with minor mods to tunnel.
Offline derwin66
AOD
« Reply #2 on: June 23, 2010, 11:39:11 am »
I thought as much.  I know the fox body AOD's will match up but dont know if they need tunnel mods.
65 T code coupe.
60 F100.
Warm 289, AOD
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
AOD
« Reply #3 on: June 23, 2010, 12:34:00 pm »
Our supplier sells AOD install kits, I will shoot them a message, asking if they know if they fit the floor.
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline derwin66
AOD
« Reply #4 on: June 23, 2010, 12:42:10 pm »
Cheers mate, looks like I will be arranging some imports.  Do you  sell the conversion kits (x-members, sandwich plate, tv cable etc).
65 T code coupe.
60 F100.
Warm 289, AOD
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
AOD
« Reply #5 on: June 23, 2010, 12:43:16 pm »
Yes, I do. If you want to import it yourself, I can sell to you and have it delivered to your agent in the US.
Custom Mustangs
Signature Sponsor
Offline Horselover
AOD
« Reply #6 on: June 23, 2010, 07:34:57 pm »
I have an AOD in my 65 convertible.
You need to adapt the shifter, get a better filler tube and depending on the extension you may need to shorten the tail shaft.
There is a new support bracket available.
You would need a different flex plate also.
Mine gives me good economy, but they can't take excessive power, so don't expect to go to the drags and run 10s quarters.
I have a 3.0:1 diff ratio and she accelerates much better than the old 2.79:1 diff.  nothing flash though.
2200RPM at 110Kmh
Warwick
Offline derwin66
AOD
« Reply #7 on: June 23, 2010, 10:31:45 pm »
You can now buy the conversion kits from the US for about $500US which includes all that is needed.  Then I guess its up to locating the AOD to handle the power.  I have 3.55 in mine and I would like it to idle a little lower on the freeways
65 T code coupe.
60 F100.
Warm 289, AOD
AOD
« Reply #8 on: June 24, 2010, 09:06:23 am »
 Mate, John Greene did have an entire conversion for a 66, at his work shop for ages, may be worth a call, New box the lot, it was in a running car and removed. Not sure if he ever sold it It would a just be a bolt all the bits in job, nothing to find, one stop shop save a lot of drama. But it may be gone.
Offline derwin66
AOD
« Reply #9 on: June 24, 2010, 09:07:06 am »
I will give him a call
65 T code coupe.
60 F100.
Warm 289, AOD
AOD
« Reply #10 on: June 24, 2010, 09:11:23 am »
May be gone but worth a call for sure.
Offline MustangNut
AOD
« Reply #11 on: June 24, 2010, 09:51:17 am »
Hey Derwin66, how much power you running? An AOD will take some serious power with a few beefed up parts. I'm running one behind my 400hp 347. I also have a spare Reco AOD, U2U me if interested.
Offline derwin66
AOD
« Reply #12 on: June 24, 2010, 10:09:09 am »
At the rear wheels about 330hp, don't kinow about at the crank.  Will drop you a message.
65 T code coupe.
60 F100.
Warm 289, AOD
Offline HEVEN67
AOD
« Reply #13 on: June 24, 2010, 07:44:49 pm »
Im going with the C6 and the Gear vendors overdrive set up on my effie...That makes it a 6 speed.
Offline Thirsty428
AOD
« Reply #14 on: June 24, 2010, 07:53:21 pm »
Also running a highly tricked AOD built in the US in my fastback.
Designed for 550 plus hp.
Drove to a mates place in the country a short while back.
In 4th gear, she was purring at low revs nicely.
I wouldn't change it.
Offline 68pony
AOD
« Reply #15 on: June 24, 2010, 08:34:16 pm »
Quote from: HEVEN67 link=topic=11111.msg116208#msg116208
Please some one frame the above coment, HEVEN67 going for a AuTo , you going soft in your old age you whimp! :smile01:
As others have said the AOD will fit with minor mods , as most know i have the electronic version(4R70W) with lock up converter ,with my 3.25 diff 65mph 2000rpm with locked converter in 4th also locks in 3rd, but i really need at least a 3.55 diff, also just for your information the 4R70w will give you a even bigger bang of the line than the AOD as it has a 2.84 1st gear verses the AOD 2.40 and 1.55 second verses 1.46 in AOD, if your running a high stall the locked converter can drop another 250-300rpm off in overdrive.
cheers chris
Offline olskool
AOD
« Reply #16 on: December 13, 2010, 12:43:07 pm »
I'm pulling my AOD out mid january has less than 1000km on it complete with 2500rpm stall convertor, lentech stg II valve body, deep alloy pan, Lokar TV cable..owes me over $3k and built to handle 550hp.... Will sell $2200, have bitten the bullet and my World series Ford Racing T5 has just arrived, and have decided to do some track days next year so the auto won't be much fun.....
You need the cross member and shorten tailshaft 25mm.....The rest is there
Will be going on Ebay mid january $2400
Harley Davidson - The most efficient way to turn fuel into noise without the benefit of horsepower.
Offline derwin66
AOD
« Reply #17 on: December 13, 2010, 03:25:50 pm »
Too late, bit the bullet and went Gear vendors
65 T code coupe.
60 F100.
Warm 289, AOD
AOD
« Reply #18 on: January 04, 2011, 11:49:18 am »
Quote from: derwin66 link=topic=11111.msg136026#msg136026
Way better idea, AOD are crap gearboxes, C4 will drive better any day. I met a bloke in Harvey Bay a few weeks back with a supa trick Bronco with a gear vendors in it was wickered.
Offline derwin66
AOD
« Reply #19 on: January 04, 2011, 05:02:33 pm »
A blast from the past Shaun.
65 T code coupe.
60 F100.
Warm 289, AOD
Offline Chello
    • http://austangchronicles.blogspot.com
AOD
« Reply #20 on: February 26, 2011, 11:53:44 pm »
This post may be a bit old now but I can add my 2 bob's worth I guess.
I imported an AOD from Monster Transmissions in the States to match the crate motor purchased at the same time. They sent all the stuff to mount it, a cooler, lokar cable, even the tranny oil! It was beefed up to take big horsepower 600+
I run it behind a 347 stroker with a bit over 400 horses.
Had to belt the tunnel with a mallet to make it fit, shorten the prop shaft, inverted the shift lever due to the B&M megashifter, cut and adjust the pacemakers . . . whew!
The end result? It is not a racing box by any stretch! The C4 I had previously shifted hard, 2nd gear chirps etc and was a much less sloppy in the shifts.
 I only put in the AOD when I "street machined" my ride as I put in a 3.55 9" diff and didn't want the thing screaming on the highway.
If I wanted to race I would have put in a manual, but I have to say the AOD is a bit ordinary in any spirited driving mode. To manually shift, the push forward to second and pull back to lock into second is just weird and takes a lot of getting used to. Plus the setting of the TV cable is very fussy and if it is not right, you will burn out the box with just a little bit of tame driving. When you add the lack of knowledge of the AOD amongst most of the local Transmission Mechanical fraternity, it spells trouble.
Mine is running adequately and seems to be lasting (been going 5 or 6 months now) on the highway it drops revs nicely . . . but if it ever blows, it's coming out and another solution will be sourced.
Electric cars aren't pollution-free; they have to get their energy from somewhere.
Offline lukep6470
AOD
« Reply #21 on: April 06, 2011, 02:31:37 pm »
You could always go a full manual BTR which would handle the power.
Maybe even make flappy paddles
http://www.shiftkits.com.au/index.php?main_page=product_info&cPath=14_26&products_id=45
Offline derwin66
AOD
« Reply #22 on: April 06, 2011, 03:56:24 pm »
Th gear vendos was made to suit a GM gearbox and they built adapters so you could put it behind a ford box
65 T code coupe.
60 F100.
Warm 289, AOD
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
AOD
« Reply #23 on: April 06, 2011, 06:08:58 pm »
GM don't make the AOD, Ford do.
GM have the T700 (Hydraulic) and later Electronic shift boxes, based on the T350, so not overly strong anyway.
I run 3.50 gears in my car, with a tall 27" tyre, and find it launches hard enough, but it is pretty loud, doing 3000rpm at 100kph...
Custom Mustangs
Signature Sponsor
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
AOD
« Reply #24 on: April 06, 2011, 07:55:18 pm »
I'm not sure what thats out of, I think it is Rodeo maybe.... Def not commodore 4 speed Auto.
I'm also not sure why you'd bother. Get a BTR 4 speed out of a EB onwards 5.0 V8 Falcon. Not very strong, but enough for most people.
Custom Mustangs
Signature Sponsor
