BRISBANE SUPERCHARGERS
Author Topic: BRISBANE SUPERCHARGERS  (Read 10485 times)
Offline derwin66
« on: June 14, 2010, 03:56:30 pm »
Discovered I have blown some seals on my Paxton 1200 and I don't want to send it to Capa in w.A.  Can anyone recommend a Brisbane company who can do it?
PS Great Idea for a restomod section.
65 T code coupe.
Blown 302. Heidts suspension, tricked C4
Gear vendors overdrive, RRS rack and pinion
Street or track roller perches adjustable struts.
60 F100.
Warm 289, AOD
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
« Reply #1 on: June 14, 2010, 04:27:38 pm »
CAPA are in SA, I thought?
CVE rebuilds blowers down here, I imagine there should be plenty of people up there that can?
Any of the big drag racing engine builders up there? Mark Brew?
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline derwin66
« Reply #2 on: June 14, 2010, 04:44:43 pm »
I stand corrected
65 T code coupe.
60 F100.
Warm 289, AOD
Offline LEE H 69
« Reply #3 on: June 14, 2010, 05:21:16 pm »
Darryl
there is a workshop in I think Randal street  slacks creek that sell and install superchargers they are called PST I think,  they have ran the dyno comps at the Brisbane hot rod shows in previous years  maybe give them a call or if you can't find their number let me know and I'll call in and quiz them for you
Offline FST68
« Reply #4 on: June 14, 2010, 07:05:59 pm »
try Redcliffe Dyno and Performance they will be able to do it.
Have you though about buying the parts and doing it yourself quite an easy job
Offline derwin66
« Reply #5 on: June 14, 2010, 08:45:07 pm »
Heard some so so stories about Redcliffe dyno.   Just negotiating what I am going to do, probably take it off and take it to somewhere to get fixed
65 T code coupe.
60 F100.
Warm 289, AOD
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #6 on: June 14, 2010, 09:11:33 pm »
Steve doesn't run Redcliffe anymore, he is now in the US, if the stories you've heard are old, or involve him.
I have no idea on the current people though.
Custom Mustangs
Signature Sponsor
Offline derwin66
« Reply #7 on: June 18, 2010, 03:18:33 pm »
Took it to Brisbane Tuning and Tubos at Nile St, W/Gabba today.  They helped the engine builder tune the car after fitting the charger.
Diagnosis - Blown ceramic seal in charger.
Cause in the opnion of the shop is quite common on this type of charger unit.  The kit does not include a blow off valve so if a back fire occurs the air is blown back from the carby to the head unit slaming into the ceramic seals in the charger and breaks them.  Apparently this type of blow backs is huge in PSI levels.  This happened a few times when I took off in the car before letting the car warm up fully and kabang.  Putting in a blow off valve, new seal in the charger, rebalanced and it should fix it.  Guaranteed work so will have to wait and see.
Apparently Paxton are quite aware of this issue but did nothing to advise people of the issue.
65 T code coupe.
60 F100.
Warm 289, AOD
Offline hybrid
« Reply #8 on: June 21, 2010, 12:30:30 pm »
It's not really Paxtons problem in my opinion.
- Stupid questions are better than stupid mistakes.
- Before you criticize a man, walk a mile in his shoes. That way, if he gets angry, he's a mile away, barefoot, and you've got his shoes.
Offline T-CODE KID
  • Name: https://www.
« Reply #10 on: June 21, 2010, 03:16:57 pm »
Maybe fatten it up some on the carb, so it doesn't pop back as well. The pop off valve should save it though we allways ran one on Dave's E type under the blower
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #11 on: June 21, 2010, 03:27:14 pm »
All blowers should run a pop off valve, for a draw thru, or blow off valve, in a blow thru.
But Paxton probably know the belt will slip absorbing most of the load. Is it a 10PK belt?
Custom Mustangs
Signature Sponsor
Offline derwin66
« Reply #12 on: June 28, 2010, 05:51:31 pm »
Stock belt (in other words I don't know the rating).  All fixed.  Both carbon seals were gone and a bearing.  It must have started sometime ago as the seals had started to damage the drive shaft.  Fitted a blow off valve under the inlet pipe. Thinking now about putting the PCV back and dropping the catch can seeing there is no blow back.
Now to move to the AOD.  Thanks god its tax time again, yahoo:fantastic:
65 T code coupe.
60 F100.
Warm 289, AOD
Offline LEE H 69
« Reply #13 on: June 28, 2010, 08:27:31 pm »
Does that mean you're all set for Lakeside then Darryl??
Offline derwin66
« Reply #14 on: June 28, 2010, 08:48:53 pm »
I am there:cool:
65 T code coupe.
60 F100.
Warm 289, AOD
Offline shelby_mustro
  • Name: Ryan
« Reply #15 on: June 30, 2010, 08:22:04 pm »
haha derwin you will have to give yourself a fine for that blow off valve!!!! :smile01:
1965 Ford mustang coupe
hipo 4bbl 347 windsor v8
t5 5 speed manual
4 wheel power assisted brakes
Other cars
1967 mustang coupe 289 c4 red
Offline derwin66
« Reply #16 on: June 30, 2010, 08:43:29 pm »
It is probably called a pop off valve, nothing like the ones the rice burners have
65 T code coupe.
60 F100.
Warm 289, AOD
  • Name: Ryan
« Reply #17 on: July 01, 2010, 11:19:17 pm »
haha yeh I know used to have a blow off valve on my r32 nissan skyline they sound good but to noisy so the piggys use to love me everytime I got pulled over by one! :smile01::smile01:
t5 5 speed manual
Other cars
« Reply #18 on: July 02, 2010, 01:35:42 pm »
Sound good ? you need your ears checked:cool:
  • Name: Ryan
« Reply #19 on: July 02, 2010, 02:38:33 pm »
hahah I did when I sold the car last week lol now its just v8 all the way now!!! just cant wait to finally stick in this new gear box in next week i got me a t5 of mr menzies yewww!!! :cool:
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #20 on: July 02, 2010, 02:40:59 pm »
oh btw derwin are you going to do the quater mile soon when ur up and running??
t5 5 speed manual
Other cars
Offline derwin66
« Reply #21 on: July 02, 2010, 02:58:58 pm »
I am up and running will be there on Sunday.  I will show you what is illegal and what isn't then boy
65 T code coupe.
60 F100.
Warm 289, AOD
  • Name: Ryan
« Reply #22 on: July 02, 2010, 03:00:55 pm »
hahah bring it!!!! :fantastic:
t5 5 speed manual
Other cars
