Radiator Shroud
Author Topic: Radiator Shroud  (Read 4090 times)
Offline Herman
Radiator Shroud
« on: August 10, 2005, 09:09:20 pm »
Can anyone tell me whether a 66 A code 4speed had a radiator shroud?
If so what is made of eg. steel or plastic and were I could locate one?
Offline 66ccode
Radiator Shroud
« Reply #1 on: August 11, 2005, 01:14:45 pm »
Herman,
Mine is a 66 C code C4, but I don't think it matters. My understanding is that all fans were fitted with a shroud. the original was a pressed steel part, which didn't fit that well but there are now plastic and fibreglass ones availiable. I saw one the other day at Mustang World in bundoora Melbourne. Bear in mind you have to make sure that your fan protrudes from the shroud by 2/3rds (someone please confirm this, it may be 1/3rd)
you may need to take some measurement depending on whether you have a two or three core radiator.
Hope this helps.
BTW do you have an overheating problem? because the shroud is supposed to be a critical component of the cooling system.
Offline Herman
Radiator Shroud
« Reply #2 on: August 11, 2005, 01:45:25 pm »
Thanks for the info.
So far no problems yet and yes I have touched some wood.
Offline NOSMustangSupplies
Radiator Shroud
« Reply #3 on: August 16, 2005, 02:00:17 pm »
a radiator shroud on an air conditioner mustang was standard equipment from the factory, though non air con mustangs came both with and without shrouds
regards.
PHILL
Offline Pete
Radiator Shroud
« Reply #4 on: August 17, 2005, 12:56:57 pm »
I think Thommo makes them.
