67 Fastback restomod
Author Topic: 67 Fastback restomod  (Read 16959 times)
Offline Stu67
« Reply #25 on: May 18, 2010, 01:06:49 am »
Slow on the updates, but large one attached :)
Well, things have been on and off, my father and mother spent 9 weeks on the east coast so the car took a little of a back seat, but now its all systems go and things are back on track. Most of the horrible work has now been done and we are starting to put things back together which is a very rewarding process i am finding.... So, where to start....
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/10-April-2010/11042010484.jpg[/IMG]
Discovered the joys of POR15, this stuff is worth every penny....
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/10-April-2010/11042010490.jpg[/IMG]
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/10-April-2010/11042010481.jpg[/IMG]
Reapiring the pillars, yes we are no Ozbilt with our body work but it will all get touched up nearer the finish
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/16052010506.jpg[/IMG]
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/02052010496.jpg[/IMG]
Tail panel and rear valance are trial fitted with Tek screws to get everything lined up and square. Tek holes to be spot welded over.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/02052010495.jpg[/IMG]
Fire wall and toe boards all repaired and painted with rust proof. Cant wait to cut the firewall and switch it up for the RHD conversion.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/02052010493.jpg[/IMG]
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/02052010494.jpg[/IMG]
Multiple sheet repairs under the back seat. My father thought it prudent to re-weld both seatbelt connections for safety's sake.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/16052010520.jpg[/IMG]
Seat risers installed. Was amazed at the added strength these put into the floor pans. Used a trolley jack under each floor pan to bring them up marginally to the underside of the riser to reverse all the sagging while a 110kg lump was sitting on them...
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/16052010519.jpg[/IMG]
My father holding the seat to check positioning. Thanks to Jtourvas for the seats, will fix the GT500 on them as mine isnt going to be a GT500 clone. Apart from that they are in superb condition. Note the burn marks on the wood, from jacking up the floor pans then spot welding. Car now smells like burnt pine!
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/16052010518.jpg[/IMG]
Right hand drive just feels more natural....good thing i dont have the windscreen in else the car noises i was making might have left residue on the glass.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/16052010512.jpg[/IMG]
Test fit of the bumper to make sure all sits square still, valance not fitted. Gas cap looks good, thanks again to Jtourvas!
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/16-May-2010/16052010515.jpg[/IMG]
Trunk lid not sitting straight, nor the quarter panel extensions, but damn i like the way its starting to shape up. Bumper shines up very well, thanks Matt from Shermatt for packing it so safely :)
Well, getting there, not bad for a weekender job with my father doing bits and pieces when he feels like it during the week. Definately getting to the rewarding part of the process.
Next.....Engine is on its way out of the fairmont, so is the wiring loom, then the dashboard and  i will fabricate my own dash and support fitting the electronics from the fairmont. Plan to have cruise control, electronic dash intruments and all the fairmont aircon etc incorporated. Going to be a squeeze but cant wait.
PIcked up most of an XW front end, so going to use these bits to get it past the licensing people, less headaches than trying to fit the fairmont front suspension and steering arrangement. $60 for the XW bits wasnt a bad find, just needs the disks replaced and calipers restored to their former glory :)
Hope to have the suspension and steering done inside the next month and the engine installed the month after that. Till then, apologies for the long winded post!
Stu
"Aerodynamics are for people who cannot build engines"
Enzo Ferrari
Offline fas66coupe
« Reply #26 on: May 18, 2010, 08:37:03 pm »
great work! car is looking great!
- Man this guy can drive!
- What, what?!
- It’s probably mostly the car
Offline Stu67
« Reply #27 on: June 13, 2010, 11:42:21 pm »
Update...
Not alot going on, chasing down bits and pieces and doing a number of fiddly bits and pieces.....my father has spent alot of time on ebay of late winning various things..... so its all coming together.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/07-06-2010/06062010524.jpg[/IMG]
Brakes are looking good, ready to go on, as is all of the front suspension. Just awaiting a few minor things like rubber boots and we are ready to roll.
Dash has been cut and welded to suit its new life as a right hand drive...
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/11-June-2010/12062010551.jpg[/IMG]
Got the old wheels and tyres off and replaced with some cheapies for now, so i can sell the 4 x white wall tyres i had the car shipped with. Makes a massive improvement, fills the guards out nicely and makes the car look alot more substantial.
Only dreaming of the day i get the CS 18's over...the white walls are for sale on the sales forum...plug plug...
Much healthier looking!
Enzo Ferrari
Offline Stu67
« Reply #28 on: July 23, 2010, 10:53:48 pm »
Been a while since i have been on here, but here is a quick update....
Home made conversion to RHD complete.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/18-July-2010/18072010574.jpg[/IMG]
No, that wheel is not staying in.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/18-July-2010/18072010581.jpg[/IMG]
Front suspension rebuilt and installed, refurbished doors cleaned up a little, panel work still to go.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/18-July-2010/18072010578.jpg[/IMG]
Converted dash fits well, need to rebuild the hinges on the glove compartment.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/18-July-2010/18072010583.jpg[/IMG]
Havent been seated in a Mustang for 15yrs, forgot just how cozy they are compared to late model vehicles.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/18-July-2010/18072010571.jpg[/IMG]
A fair bit of work has gone on that isnt in the pictures, like the brake booster being installed and she shelby drop completed. The EFI motor in the fairmont is ready to come out and will be slotted snugly in the engine bay this weekend, cant wait to see the stance with the engine in it.
Images resized to fit for you
[Edited on 15-8-10 by CPU]
Enzo Ferrari
Offline mikes68
    • www.mikes68.blogspot.com
« Reply #29 on: July 24, 2010, 02:56:33 am »
Great progress there Stu... :thumb:
Mike
Offline Petey
« Reply #30 on: August 11, 2010, 01:14:57 pm »
Great progress Stu67,
Mine has been on a rotisserie for over a year, so now I feel really slow.
I would be really interested in how you did the instrument cluster swap to RHD. There are several guys in Melbourne who charge heaps to do it and the quality varies enormously.
My idea was to make a mould and construct a new one from fibreglass, but that would require skills I have not developed, so might have to consider alternatives.
PT
Offline 67fasty.sm
  • Name: shane
« Reply #31 on: March 14, 2011, 01:01:19 pm »
hey stu67,
any chance you can put a link to your photobucket would love to see what you have done , as I have a 67 fb project on the way which is going to restomoded as well
67fasty.sm
Offline 67fasty.sm
  • Name: shane
« Reply #32 on: March 14, 2011, 01:04:13 pm »
Hey Petey,
Go to RRS suspension web site they have made a repo 67 rh dash gauge cluster and lh glove boxside looks good from the pic's hope this helps
cheers
shane
