The engine was described to me as "Running when parked" at the time of purchase. Upon getting the car it was noted this was a very broad term, perhaps the seller meant "running before i parked it, stripped the heads, exhaust, radiator, all electrics" Engine looks to have sat for a long time with the bores open to the elements and water sitting in them.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/30-Jan-2010/23012010413.jpg[/IMG]
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/30-Jan-2010/23012010420.jpg[/IMG]
Note the missing core plug....
Sump was full of corrosion.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/30-Jan-2010/23012010421.jpg[/IMG]
Pistons rusted solid to the bores, looks like water has sat in the sump until the sump rusted through and it drained out.
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/30-Jan-2010/23012010422.jpg[/IMG]
Engine is pretty much ruined, not worth the time to chisel out the pistons, resleeve and repair everything, so the donor vehicle we need has to have a good, solid engine. Note that when the prop shaft dropped out the back of the c4, a lovely, red milky sludge drained out, so looks like water has been sitting in the gearbox for some time too.
The recent purchase of the following donor car will make a big difference...
[IMG=700x525]http://i177.photobucket.com/albums/w219/jarvegimite/06-Feb-2010/06022010444.jpg[/IMG]
Purchased an entire EF fairmont for $1k, its a wreck but the engine starts and sounds great, its been modified and dyno'd at 300 rear wheel HP. Gbox is good too with a LSD rear end, only problem with it is that a small Japanese vehicle tried to get into the front passenger seat and by the look of the damage, nearly got the seatbelt clicked in too. Structurally its a write off but mechanically its in top condition.
