Say Hi to Helleanor
Author Topic: Say Hi to Helleanor  (Read 87378 times)
Offline soc123_au
Say Hi to Helleanor
« Reply #200 on: June 26, 2012, 03:37:35 pm »
Havent spoken to them yet. Will stay up late tonight & give them a call. I can get pistons here, but 4 week minimum wait. Or buy a 427 block if I can find one. It will have some serious cubes then. The cost of this engine is getting way out of hand now though. I now can confirm what FE stands for, the E is expensive, the F well that is easy enough to work out.
Offline blackthunder1970
  • Name: barry
Say Hi to Helleanor
« Reply #201 on: June 26, 2012, 05:17:43 pm »
hi soc 123-au
welcome to the fe club :thumb:
your just playing with little brother
step up to big brother 427 and your know the meaning of f...king expensive
if i knew the true cost of building my 427 cammer i would have had second thoughts
if your get stuck on any little parts for you fe that will hold your build up let me know as i have a lot of fe stuff
cheers
barry
1970 brandy wine  427 cammer mach ch 1
1970 blue 428 cj mach 1
1970 blue 428 scj w code mach 1
1970 r code convertible 1 of 12
1970 gt 500 convertible replica
1969 shelby gt500 real one
used to own
2 66 fastbacks
69 boss 302 original paint yellow
69 boss 302 project
69 mach 1 428cj blue
69 mach1 428 scj red auto
69 mach1 428 scj black 4 speed
69 mach 1 351 4v auto
70 mach 428 cj matching number j white stripe
70 mach 1 428 cj grabber orange
70 mach1 428 cj auto white
70 mach1 428 cj auto white fully optioned
70 mach1 428 cj auto yellow original paint should have keep it
70 boss 302
Offline soc123_au
Say Hi to Helleanor
« Reply #202 on: June 26, 2012, 06:32:09 pm »
Hi Barry, you wouldnt have a 427 block lying about would you. The pistons I got are 4.260 so I think they are to suit a 30 thou over 427. I have pretty much everything else. I am pretty sure all the other stuff I have would suit any FE block. I wish I had had second thoughts as well, for what I have spent so far I could have had an injected supercharged windsor with nitrous up & running by now. Probably with enough left over for a few tanks of fuel:banghead:
Offline moe
  • Name: "Moe"
Say Hi to Helleanor
« Reply #203 on: June 26, 2012, 06:45:09 pm »
I do know of a Big Block in a '69 near you Soc....  At the ranch....  I'm sure he's not going to need it in a hurry, could do with some running in :cool:
  • Name: barry
Say Hi to Helleanor
« Reply #204 on: June 26, 2012, 06:55:55 pm »
hi
no 427 blocks  only one i ever owned is the ali  genesis block in my black car
plenty of 428 cj blocks and engines and parts spares for my cj mach 1 s
build a 428 instead of a 390 and you wont regret it
a 427 block would cost between 2500 to 4000 depending if it a side or top oiler
i can check a few of contact and see if they have a 427 block
barry
used to own
2 66 fastbacks
69 boss 302 project
70 boss 302
Offline Cage
Say Hi to Helleanor
« Reply #205 on: June 26, 2012, 08:13:03 pm »
[rquote=183123&tid=6878&author=soc123_
Had a bit of a setback yesterday, the pistons I had waited on since February are the wrong ones. They sent 30 thou over 427 pistons instead of 390. :banghead:[/quote]
Helleanor is cursed. :soap:
What's going to not turn up next. Sorry to hear this mate.
Think of it this way, more time to spend on Brandy, :bolt:
Offline soc123_au
Say Hi to Helleanor
« Reply #206 on: June 26, 2012, 09:05:38 pm »
Yes, I am beginning to think that Cage. Bloody thing better be worth it when its finished.
Barry f I didnt have most of the stuff already I would consider a 428. The only reason I would go 427 is it would put the pistons to good use & the extra cubes would be nice. The bits I already have are
Dove Medium riser alloy heads (60cc)
Dove single spyder intake with injector bungs
Fast XFI Injection
Scat 4250 Steel Crank
BB Chev H beam Rods
Diamond Forged Flat Tops (extra large)
Comp Cams Magnum 306s solid flat tappet
Dove Roller Rockers
Appropriate lifters, valve springs etc.
Concept One pulley kit
Cobra alloy sump
ARP head studs, rod bolts etc.
Its all ready to get built except the 390 block & the pistons wont work.
  • Name: barry
Say Hi to Helleanor
« Reply #207 on: June 26, 2012, 09:11:26 pm »
hi
check out the dove heads and intake and see if they are pourous dove is bad for that
dove rockers are good
cheers
barry
ps the crank will cost about 1000 to balance
give me a call on 0429695845 and i will give you a few tips
used to own
2 66 fastbacks
69 boss 302 project
70 boss 302
Offline soc123_au
Say Hi to Helleanor
« Reply #208 on: July 15, 2012, 09:45:45 am »
The old girl has had a bit of love in the past month, its been a long time coming.
Here it has been blocked with 120 to get in nice & straight & the panel gaps massaged to where we want them. Then it gets hifilled again.
Here it has been blocked again with 180 then wet rubbed with 400 & then again with 800. It has just been painted through the centre for the stripes.
Offline soc123_au
Say Hi to Helleanor
« Reply #209 on: July 15, 2012, 09:48:17 am »
Now another hit with 800 & a cut with 1200 over the white areas.
Then it is reassembled, so the stripes can be masked off
Offline soc123_au
Say Hi to Helleanor
« Reply #210 on: July 15, 2012, 09:50:12 am »
The tedious masking process.
Offline soc123_au
Say Hi to Helleanor
« Reply #211 on: July 15, 2012, 09:51:39 am »
Then pull it apart again:toetap:
Offline soc123_au
Say Hi to Helleanor
« Reply #212 on: July 15, 2012, 09:53:32 am »
Now the fun part can begin. 1 coat of grey base followed up with 3 coats of silver.
Offline soc123_au
Say Hi to Helleanor
« Reply #213 on: July 15, 2012, 09:54:40 am »
4 coats of Candy.
Offline soc123_au
Say Hi to Helleanor
« Reply #214 on: July 15, 2012, 09:56:24 am »
Unmask the stripes & lay on some clear.
Offline soc123_au
Say Hi to Helleanor
« Reply #215 on: July 15, 2012, 09:57:57 am »
It was a few week process to get all that done. The actual masking & final colour was done yesterday. I cant wait until tommorow to push it out into the sun.
Offline Gretschem
Say Hi to Helleanor
« Reply #216 on: July 15, 2012, 10:03:35 am »
Looks very nice...what brand of paint did you use???
Offline soc123_au
Say Hi to Helleanor
« Reply #217 on: July 15, 2012, 10:13:45 am »
Standox. The candy is HOK shimrin base.
Offline j1autotech
  • MOCA VIC member 1828
  • Name: Justin
Say Hi to Helleanor
« Reply #218 on: July 15, 2012, 10:55:27 am »
WOW !!!   :shocked:
That is the ducks nuts...
Awesome.
:bow:
J1
Offline soc123_au
Say Hi to Helleanor
« Reply #219 on: July 16, 2012, 09:31:19 am »
A couple of pics in the sun.
Offline soc123_au
Say Hi to Helleanor
« Reply #220 on: July 16, 2012, 12:42:46 pm »
Got a few better ones with a decent camera & the suspension looking a little less Landcruiser.
Offline Cage
Say Hi to Helleanor
« Reply #221 on: July 16, 2012, 08:10:11 pm »
Looks awesome Steve. Remind me to never go finishing with you. :shrug:
Offline FPVF6
Say Hi to Helleanor
« Reply #222 on: July 16, 2012, 08:19:21 pm »
Looking smick mate
I have told the missus .I am going to buy a mustang so deal with it
Offline Yellow66
  • Car: 1966 coupe & 1969 Mach 1
Say Hi to Helleanor
« Reply #223 on: July 16, 2012, 09:03:44 pm »
Gorgeous Steve, well done
Offline j1autotech
  • Name: Justin
Say Hi to Helleanor
« Reply #224 on: July 16, 2012, 09:04:15 pm »
If I was in town, I'd fly up and take photo's for you Steve.
:cpics:
