6t9rustang
Author Topic: 6t9rustang  (Read 5793 times)
Offline 69mach1
6t9rustang
« on: April 29, 2009, 02:58:51 pm »
I sent you an email Russ did you receive....work related.
Offline 6T9rustang
6t9rustang
« Reply #1 on: April 29, 2009, 08:13:59 pm »
Check U2U.:=
Offline xboss
6t9rustang
« Reply #2 on: May 12, 2009, 09:53:50 am »
LOVE THE CAR
JUST WONDERING WHERE YOUR RUNNING THE EXHAUST.
I HAD THE SAME REAR END ,IF YOUR RUNNING OUT THE BACK I CAN GIVE YOU A COUPLE OF TIPS.
Offline 6T9rustang
6t9rustang
« Reply #3 on: May 12, 2009, 09:02:51 pm »
its almost too late with the fuel shroud where it is, for tail pipes. just going to run dump pipes before the diff. not that i really wanted to but getting 3inch pipes through that suspension was going to be difficult! the aluminium tank was a lot squarer than a factory item and that too took even more room.:( still open to tips though!!
Offline fordtj69
6t9rustang
« Reply #4 on: May 12, 2009, 09:09:31 pm »
hi russ go to mustang unlimited cattledog page 126 dr gas side exhaust nice oval side pipe :( thanks tim
                         BDCC
Offline 6T9rustang
6t9rustang
« Reply #5 on: May 12, 2009, 09:12:08 pm »
cheers.. will do!:(
Offline 6T9rustang
6t9rustang
« Reply #6 on: May 12, 2009, 09:23:09 pm »
I had a look nice but i just remembered that the sub-frame connectors took out the option of side pipes!!:-
