fuel question
Author Topic: fuel question  (Read 2700 times)
Offline ron
fuel question
« on: July 18, 2006, 12:55:09 pm »
Due to this, that and the other thing my car has been sitting idle for 2 months.Still has half a tank of Optimax.Anybody know how long this stuff stays stable.Don't want to run around with stale fuel and with these current prices, a bit hesitant (tight assed) to drain it . Thanks.
Money is made to be spent.
Offline Bashfull
fuel question
« Reply #1 on: July 18, 2006, 07:50:57 pm »
in an old car,,,fuel sitting around suffers a couple of promblems....
1, the natural heating and cooling of the tank due to temp flucations...let the violatiles out and water in...
but at half a tank...when you go again...just top it off..
just done expect good perfrmance out of old fuel...
Offline jas24zzk
fuel question
« Reply #2 on: July 18, 2006, 11:18:18 pm »
Avgas normally comes with a shelf life.
In drum form that life is marked clearly.
2 months isn't long as avgas is 6.
If you are worried about it, you could always dilute it with some fresh fuel.
Jas
Offline FMACHI
fuel question
« Reply #3 on: July 20, 2006, 10:02:43 am »
I have the same concern. Don't top it up unless your going to drive and use most of it. If your going to leave the car in the garage for a while. Try and park it with 1/4 to 1/2 a tank. Otherwise, next time you'll have the same concern.
I tend to put no more than $20 in mine unless I'm going for a bit of drive. That way it's always fresh.
Have you concidered draining it, and using the fuel in your every day car?
Why be standard, when custom is so much more fun!!!
Offline ron
fuel question
« Reply #4 on: July 20, 2006, 06:58:11 pm »
Would if I could, but I'm a farm boy so it's diesel for me.However ,with the petrol doped up to the eyeballs with octane boost might have a bit of fun with the ride on.LOL!!
Offline yianni351
fuel question
« Reply #5 on: July 20, 2006, 07:58:35 pm »
I bought an old 318 Valiant many years ago which has been sitting for 11 years with a full tank.
A little bit of 2 stroke mix to fill the carby bowl & it ran fine on the 11 yo fuel.
2 months sitting should be fine.
Offline FMACHI
fuel question
« Reply #6 on: July 22, 2006, 08:21:08 pm »
I've been drving for 12 years now, and I'm certain petrol has changed. Not only is it 3 times the price, it doesn't last as long either.
Offline Bashfull
fuel question
« Reply #7 on: July 28, 2006, 07:14:09 pm »
hi,
after some reading and some thinking...the answer to the fuel quiestion,if you are going to stroe a car for a while..
store it with a full tank...it is the volume of air in the tank that gives water to the fuel....
