Newton Metres on Diff
Author Topic: Newton Metres on Diff  (Read 1999 times)
Offline Petey
« on: June 19, 2006, 07:39:29 am »
Don't worry about the torque on the pinion seal nut.
Leaking from the pinion seal is a common problem which is easily fixed.
Just remove the nut and apply a thick silicon bead around the pinion. refit the nut and tighten to a firm tension so there is no play in the bearing and I guarantee the leak will be gone!
PT
Offline carlt
« Reply #1 on: June 19, 2006, 11:51:35 am »
thanks pt your information is muchly appreciated
