spare wheel needed for 66 coupe
Author Topic: spare wheel needed for 66 coupe  (Read 2329 times)
Offline scottdogs
« on: June 09, 2006, 04:16:58 pm »
Hi, I just bought a 66 coupe recently and have noticed that it doesn't have a spare wheel.
Does anyone know the easiest way to find myself a spare? would it be a standard purchase from a tyre place ... or perhaps from another ford?
rgds
Offline nassi
« Reply #1 on: June 09, 2006, 08:34:38 pm »
Just go to your local wreckers, they are the same as Falcon rims, you will need to know if you have, 4 stud or 5 stud. If you have 5 stud (V8), then be aware that there are two centre sizes. The large centre will fit also fit both hub sizes, and obviously the small centre will only fit the smaller hub.
nassi
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline Bashfull
« Reply #2 on: June 12, 2006, 04:15:40 pm »
go to a trailer place and buy yourself a new rim...
a new falcon rims 14 x 6jj will set you back about 45 dollars
brand new and in black...no work neded...
be aware that fitting radials to real old rims..is extremely dangerous..if you find a rim with a small centre it is not designed to take a radial..
