Window mouldings how do you remove them
Author Topic: Window mouldings how do you remove them  (Read 2237 times)
Offline 66pony
« on: September 08, 2008, 12:45:14 pm »
I have almost got my 66 coupe on the road but last friday I took it to the engineer to get it checked off, it rained heavily and I discovered a significant leak in the lower corner of the rear screen.  The rubbers are probably '66 vintage but I don't want to replace then just yet.  I want to get some mastic into the area but I can't get the stainless mouldings off - I have applied some force but don't want to damage them.  The workshop manual I have says to use a tool (can't remember the number) to  remove the trim.  I have tried paint scrapers but this hasn't worked.
Is there a trick to this so that the mouldings can be reused??
Steve
Offline Frank70
Offline 66pony
« Reply #2 on: September 09, 2008, 12:25:40 pm »
Thanks Frank
How do you use the tool, does it go under the trim from the glass side?, do you need to use much force to get the trim off?
Steve
Offline Frank70
« Reply #3 on: September 09, 2008, 01:30:06 pm »
Hi Steve.
Sorry, but I dont know - dont actually have one. Was looking at getting one to remove the trims for when I paint the car.
Frank.
Offline 66pony
« Reply #4 on: September 10, 2008, 12:35:22 pm »
Any one else have any information on how to get the window mouldings off??
Steve
Offline 2+266
Offline nassi
« Reply #6 on: September 10, 2008, 07:51:09 pm »
Steve
It may sound rough but it works - I use a piece of wood about 1.5 inches wide against the under side of the moulding and then gently tap the wood with a hammer. Goes easy and take your time.
Oops just reread the post, ignore my 2 cents worth. I was referring to the driprail moulding, sorry.
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline blackbox
« Reply #7 on: September 12, 2008, 07:21:00 am »
Dont ask me I did a s#@t job with mine, they need some work now to get them back to good again. This is not a job to do when you are feeling impatient and tired after laying under your car all day:*
James.
Offline 64half
« Reply #8 on: September 12, 2008, 07:34:25 am »
Steve,
Don't risk damaging them. The rubbers are cheap and the windscreen guys don't charge too much. I'd go that way.
Dave
Offline 66pony
« Reply #9 on: September 15, 2008, 12:14:33 pm »
Originally posted by 64half
Steve,
Dave
Dave I am inclined to agree with you as I now have a couple of nice dents in one of the mouldings (Doh!!) where I tried to remove it with a tool.
Anyone know where I can get the vertical moulding for a 66 coupe (rear screen) for the left hand side??!!.
Steve
Offline 64half
« Reply #10 on: September 15, 2008, 09:10:26 pm »
Woops!
I have a new rubber if required.
Just had front and back windows refitted.
I had one but got the extra when I bought seal kit.
Dave
