Engine Number
Author Topic: Engine Number  (Read 2973 times)
Offline tooblue
Engine Number
« on: April 06, 2006, 04:18:49 pm »
Hi,
Can someone tell me where I find the engine number on my '641/2. I have the original tag which is under a bolt, but don't know whether there should be a number other than these.
Offline nassi
Engine Number
« Reply #1 on: April 06, 2006, 07:08:03 pm »
What engine do you have ? Not that I can answer the question but it will help those who can.
nassi
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline Herman
Engine Number
« Reply #2 on: April 06, 2006, 08:47:55 pm »
Tooblue
If memory serves me correctly unfortunately there is no engine number stamped on a 64 1/2 engine block.  However you maybe only beable to decode the original tag you have.
Herman
Offline 66ccode
Engine Number
« Reply #3 on: April 07, 2006, 11:07:46 am »
Herman is correct. There is no engine number on anything up to 67-68 I think. however, if it has been registered in Aust, it should have had an engine number added by Vicroads or the equivalent.
Offline Mustang-kid
Engine Number
« Reply #4 on: April 07, 2006, 04:19:06 pm »
:f  I used my car vin number as my engine number, and it was all ok. Use the last 5 or 6 numbers of your vin. ;*
Offline tooblue
Engine Number
« Reply #5 on: April 07, 2006, 08:43:16 pm »
Thanks everyone. The car has an A code engine, 289 4V and there is a number on the rego papers which was issued by the transport dept. I am lucky in the fact the tag is still attached which has 289 65 5 and underneath 4-H 553 J but I would have like to known where the engine number was for myself. At least I know now, that there probably isn't one anywhere.......Ta again, Too Blue
Offline 64half
Engine Number
« Reply #6 on: April 10, 2006, 10:03:08 am »
Hey,
There is definitely no eng number. Use the last digits of the vin. If you are in NSW stamp it b4 you go for the blue slip. This will save a double trip to the RTA.
David
