FE 390 Timing Pointer
Author Topic: FE 390 Timing Pointer  (Read 2244 times)
Offline Tiny
  • Car: 66 GT Coupe
« on: September 30, 2023, 12:24:53 pm »
Hi all, is there a reason why my timing pointer is so far away from the Harmonic Balancer.  The HB is a C4AE-6316-B.  Even the photos I have seen with the same HB is much closer to Timing Pointer.  At first I thought it was that the HB was not on far enough (Wrong Spacer) but if that was the case then the fan belt would not line up.
Can anyone assist
thanks
67 390 GTA Coupe with Vinyl Roof
PS, A/C
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
Re: FE 390 Timing Pointer
« Reply #1 on: September 30, 2023, 10:15:10 pm »
Think your harmonic balancer is different to what may have originally been there.
Have a look at the pictures on this web site.
https://www.squarebirds.org/simplyconnected/390Build/TimingSetRemoval.htm
Offline Tiny
  • Car: 66 GT Coupe
« Reply #2 on: October 02, 2023, 06:55:12 am »
Thanks Clubman for the pics.  There seems to be multiple variations of the HB to fit 390's so I think I will need to identify the correct part number and then search for the correct HB.
cheers
PS, A/C
« Reply #3 on: October 04, 2023, 12:26:32 pm »
the HB is a '64 item, and you have a mismatch with the timing pointer - replacing the pointer would solve your trouble here.
Compare your one (which appears to have the tip cut off) with these:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p4432023.m570.l1313&_nkw=1964+390+timing+pointer&_sacat=0
Offline Tiny
  • Car: 66 GT Coupe
« Reply #4 on: October 10, 2023, 11:56:47 am »
Excellent thanks Jiffy, I will source the correct length Pointer.  No sure what the one is on my engine but it is certainly to short.
thanks
PS, A/C
