67 S-code is dead - no electrical activity
Author Topic: 67 S-code is dead - no electrical activity  (Read 2384 times)
Offline gavin57
  • Name: Gavin
  • Car: 1967 GTA 390 Coupe
« on: September 25, 2023, 07:42:52 pm »
Looking for advice - I have a 67 S-code that is completely dead. Motor won't crank, no lights, no horn, no dash lights.
Battery is near new and has tested good, starter solenoid has been checked and is good (bypassing the ignition switch has the engine cranking over.
No volts from the ignition switch when it is turned on.
My guess is ignition switch is faulty but the lights and horn etc not working is confusing me.
Any thoughts/suggestions?
Offline 6t9m1
Re: 67 S-code is dead - no electrical activity
« Reply #1 on: September 25, 2023, 08:46:10 pm »
Solenoid wiring may be wrong.
Post a picture so we can check.
The big post on the solenoid that is connected to the battery should also have a smaller wire that connects into wiring loom note these wires should be on the same post.
The other post will send power to the starter.
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #2 on: September 25, 2023, 10:39:45 pm »
Agree with solenoid worth checking.
Next voltage reg, bulk head connector then fuse box
You really need a multimeter to follow the voltage and look where it stops
https://www.clanmcmuffin.com/64%20Mustang%20Wiring%20Diagrams%20(Colorized).pdf
Link to schematic
does anyone remember laughter
Offline RocketScientist
« Reply #3 on: September 26, 2023, 06:42:26 pm »
I had a worn ignition switch on my 67 do that to me - turn the key and it shut everything down.
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #4 on: September 26, 2023, 07:50:18 pm »
Interior light, horn, cigarette lighter should work ignition on or off
« Reply #5 on: September 27, 2023, 10:26:28 am »
My instance killed everything - not the best thing when you're at the servo trying to fill up.  :cry:  At the time I put it down do the starter solenoid or the switch and firstly replaced the solenoid as it was the easier thing to do. After finding no change, replacing the switch fixed everything.  :smile01:
Offline 6t9m1
« Reply #6 on: September 27, 2023, 08:57:05 pm »
Check the earth connections.
There should be at least two, one from the negative battery post to the engine block and another from the engine block to the body.
 i.e. remove and check for corrosion then if found clean and resecure. :bolt:
