mustang gt 2017 ignition problems
Author Topic: mustang gt 2017 ignition problems  (Read 2122 times)
Offline math
  • Name: matt holtom
  • Car: mustang gt 2017
« on: March 26, 2023, 07:34:54 pm »
Hi there,
I have an issue with my mustang gt 2017 were the at times my engine wont crank over. It's very unusual as it won't happen straight away but after a short trip ill turn it off,then turn it back on and it won't crank over. I have taken it to multiple mechanics and telling me they are unable to find the issue. I was hoping to try my luck out here. I have attached a video.
Any feed back would be much appreciated.
Offline unilec5544
  • Name: Neil.
Re: mustang gt 2017 ignition problems
« Reply #1 on: March 26, 2023, 07:56:56 pm »
It sounds like an issue with your neutral safety switch. Forgot to ask if it's manual or auto?
 cannot see any video.
« Last Edit: March 26, 2023, 08:00:28 pm by unilec5544 »
Offline math
  • Name: matt holtom
« Reply #2 on: March 26, 2023, 08:46:11 pm »
Its manual. Sorry it won't let me upload the video on here,I will keep trying.
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
« Reply #3 on: March 26, 2023, 09:19:18 pm »
I’d imagine by now the original battery has been replaced?
If not it’s time.
Offline math
  • Name: matt holtom
« Reply #4 on: March 26, 2023, 10:34:32 pm »
Yes, the battery has been replaced along with new terminals.
Battery has been checked over by a reliable source. Issue still occurs.
Offline unilec5544
  • Name: Neil.
« Reply #5 on: March 27, 2023, 04:21:42 pm »
Have a look high up on the clutch pedal and see if the is a switch, may prevent you starting the car in gear.
Offline math
  • Name: matt holtom
« Reply #6 on: March 27, 2023, 05:26:48 pm »
Hi.
Yes I have looked at the clutch switch and it seems fine. The problem seems to occur when the vehicle has warmed up. So its a bit of a funny one. I can start it ten times out of ten and its fine. I'll go for a drive, then turned it off , then try turning it on again and it may or may not crank over.
Offline FB.65.68.70
« Reply #7 on: March 27, 2023, 08:36:59 pm »
Hi Math,
Ive got a 2017 gt but thankfully havent got the same issue.  Yours sounds like your starter or cable to the starter is getting hot and wont take the charge / turn the engine.
Have you recently put a custom set of headers on ?
 My early mustang had a set of headers and same as your symptom,  would start the engine cold, but not when it was warmed up. Fix was to put a heat insulator blanket over the starter, has been good since.
Not sure if this helps you , but good luck in getting a fix.
Regards
Mark
Offline math
  • Name: matt holtom
« Reply #8 on: March 28, 2023, 04:43:37 am »
Hi Mark.
Thanks for that, it does make sense why that issue would occur. I will look into this further.
Thank you!
