No windscreen wiper water
Author Topic: No windscreen wiper water  (Read 2784 times)
Offline monoking@yahoo.com
  • Car: 2018 GT
« on: February 27, 2023, 01:59:41 pm »
My 2018 GT windscreen wipers are not pumping water. The pump makes a sound and a few drops come through, but that's it. Yes - the reservoir is full. I took the pump out and checked it, but it is a fully-sealed unit so couldn't really see anything wrong with it. The connections were fine. Just wondering if anyone else has had this problem before I buy a new pump and hope it fixes the problem.
Re: No windscreen wiper water
« Reply #1 on: February 27, 2023, 08:17:10 pm »
Hey,
Grab your garden hose and slightly pressurise your washer tank!
See if that helps.
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
« Reply #2 on: February 28, 2023, 04:47:54 pm »
Read that the hose from the tank can get crushed by the hood hinges.
Have to follow your hose and check its alright.
  • Car: 2018 GT
« Reply #3 on: March 17, 2023, 10:11:19 am »
Thanks AussiePhil - that fixed the problem. Appreciate the advice.
« Reply #4 on: March 17, 2023, 02:47:45 pm »
Hey mono,
Glad it helped!
