Water Leaks From Under Wheel Arches
Author Topic: Water Leaks From Under Wheel Arches  (Read 3355 times)
Offline Peter Delaney
  • Name: Peter
  • Car: 2018 Mustang GT V8
« on: September 02, 2022, 05:49:41 pm »
I have a 2018 FN GT, and have a problem with water gradually dripping onto the garage floor after driving on wet roads.  I can leave the car out on the driveway on rainy days & have no problem - it is only when driven on wet roads that water is flung around the inner guards & seems to accumulate in voids behind the inner guards, then slowly drips out.  Most pronounced is the rear guards - I have measured 250ml of water dripping from both the front & back of the inner guards !
Has anyone else had this problem, & if so, found a fix for it ?
Kind Regards,
Peter
Re: Water Leaks From Under Wheel Arches
« Reply #1 on: September 02, 2022, 07:24:22 pm »
Hey Peter,
My wife has the same problem with her Mazda.
I find a mop is very handy!
Sorry, I couldn’t help it!  :grin:
Hahaha.
  • Name: Peter
« Reply #2 on: September 02, 2022, 08:33:34 pm »
Hi Phil - Yep, a mop is the only solution - other than just leaving the car out in the driveway until it has finished dripping !
It's a good thing that I am not one of those wealthy enthusiasts who park their toys in a carpeted garage !!
Mind you, I find it a bit strange that I can't find any reference to this problem on the web.  How can I be the only owner who has this problem at the front & back of all wheel arches ??
One of life's little mysteries :)
Kind Regards,
Peter.
« Reply #3 on: September 03, 2022, 07:05:05 am »
Hey Peter,
My garage floor is painted but to stop slipping on a glossy surface I added dulux anti slip (fine glass), probably to much!
It’s a pain because it doesn’t mop up very well and is stained.
Hope you find an answer!
