Question regarding American autowire instal
Author Topic: Question regarding American autowire instal  (Read 9162 times)
Offline tired69
« on: August 20, 2022, 08:25:22 pm »
To any one whos rewired a 69 with American Autowire kit .
Ive just started got fuse box mounted next step mount relay block but theres no where to put it as the wires are not long enough to mount to right handside of steering coloumn where there is space.
If any body done this instal or has some advice would be of great help.
Offline Greg Dobe
  • Name: Greg Dobe
  • Car: 69 & 70 R Code SCJ
Re: Question regarding American autowire instal
« Reply #1 on: August 20, 2022, 09:23:48 pm »
Hi,
Doing the same right now as well in a 70 MACH1. Found the same problem, I am going to mount on top of the low dash panel. Will need to remove the dash pad to get access if any of the relay’s need replacing. It would be good to compare progress and ideas if your interested?
Regards Greg
Offline tired69
« Reply #2 on: August 21, 2022, 11:11:26 am »
Thanks greg.
Yeah for sure
i thought  about that seen as its  really the only spot..
My whole dash is out slowly putting  it all back together.
Offline sms777
« Reply #3 on: August 21, 2022, 09:36:25 pm »
Just out of curiosity,......are you gusys talking left hand drive or right hand drive cars. I have fitted several of these kits into original left hand drive cars with no issues.
Offline Greg Dobe
  • Name: Greg Dobe
« Reply #4 on: August 22, 2022, 09:02:10 pm »
My car was convert to right hand drive back in the 70’s then back to left hand when the laws changed. Due to the modifications and massive cutting and shutting I decided to go down the path of an aftermarket kit. So far it’s been straight forward other than all the OEM plug ends are long gone.
Regards Greg
Offline tired69
« Reply #5 on: August 24, 2022, 04:42:01 pm »
Hey greg.
Just nutting out this wiring  there doesnt seem to be any wires going to actual heater blower motor etc  have you noticed this  im not sure if its the same set up 69-70going to check out old harness see if theres a seperate loom from the controls to the heater.
Cheers.
Darryl.
Offline Greg Dobe
  • Name: Greg Dobe
« Reply #6 on: August 24, 2022, 07:06:06 pm »
Yep found the same thing. I utilised the plugs from the old harness and rewired. Do you have the old harness so you can do the same?
Offline tired69
« Reply #7 on: August 31, 2022, 03:46:56 pm »
Hi greg.
Yes just copied old harness etc.
What amp relays did you use for lights etc..
Cheers darryl.
