289w swap 351c in 1965 Mustang Coupe
Author Topic: 289w swap 351c in 1965 Mustang Coupe  (Read 10005 times)
Offline Fred Coupe 1965
  • Name: Fred
  • Car: 1965 Mustang Coupe
« on: July 30, 2022, 05:10:50 pm »
Hi All, hope you all having a nice weekend . My topic is , With a swap 289w to 351c in a 1965 Mustang Coupe. is there any structural to the body and front end..?!  or just turn key and go Cruising.
Re: 289w swap 351c in 1965 Mustang Coupe
« Reply #1 on: July 30, 2022, 05:31:07 pm »
Well the deck height is larger than a 289 so the whole thing is higher and wider and things are pretty tight to start with in the early cars. I think a 351 Windsor is even bigger than a Cleveland though and there are plenty of them in an early Mustang. It will be very tight though and I really don't know why you'd bother given that a stroked 302 Windsor will be a better engine all round.
This might be worth a read.
https://www.allfordmustangs.com/threads/351-cleveland-into-1965-mustang-coupe-questions.76441/
Offline Dingo80
« Reply #2 on: July 30, 2022, 05:33:23 pm »
I have a 351W in mine and it bolts straight in. Headers are tight and so are plugs. Car used to shake as headers just touched shock towers. I have now notched my shock towers and there is heaps of room.
« Reply #3 on: July 30, 2022, 07:06:09 pm »
Hey Fred,
I’d only put in a 302 Windsor, you’ll have much better room and they rev nicely.
As Dingo and Geoff say they fit but only just!
In a 66 Mustang with a 302 it will have all the power you need, unless you want ridiculous power.
In my experience don’t fit the later EFI 5L engine, unless you want to change it back to a carburettor, and remove the ECU.
If you keep the EFI ECU you can not add many modifications, the ECU won’t adjust to suit!
Saying that you will need to fit a new intake manifold, distributor and carburettor, You may also want to fit Alloy heads, new headers, Cam, bigger twin exhaust, add Borg Warner T5 gearbox and 9” housing and LSD. Plus you will need an Engineers certification, the price is adding up!
It all depends on what you want, but it could cost you heaps.
I stroked my 5L EFI to 347ci, then you worry about breaking the two bolt mains, in hindsight I would have felt more comfortable with a 331ci.
I have Unisteer power steering and had trouble getting the right headers to suit it and the transmission Z bar.
And I have enough trouble changing the spark plugs.
But I don’t want to turn you off what you want, it is very rewarding!
Whatever, enjoy your car.
« Reply #4 on: July 30, 2022, 08:04:51 pm »
Are you saying a 351 Cleveland?
  • Name: Fred
« Reply #5 on: July 30, 2022, 08:21:22 pm »
Thanks for the guidance.
  • Name: Fred
« Reply #6 on: July 30, 2022, 08:23:02 pm »
Thanks for the advice.
  • Name: Fred
« Reply #7 on: July 30, 2022, 08:24:49 pm »
Hey Fred,
Thanks for the direction.
  • Name: Fred
« Reply #8 on: July 30, 2022, 08:25:50 pm »
Thanks for advice.
  • Name: Fred
« Reply #9 on: July 30, 2022, 08:26:49 pm »
« Reply #10 on: July 30, 2022, 08:29:43 pm »
A 351windsor just fits ,extractors are a  pain , it’s a taller engine too . A351 Cleveland is a no go . 351windsor needs a good export brace and a Monti Carlo bar fitted . Torque boxes should be fitted as well . A 289 stroker to 347 is the go . I have owned a 65 with a 351windsor and a 66 with a 347 before ,now own a 70 with a 408 stroker .
  • Name: Fred
« Reply #11 on: July 30, 2022, 08:30:13 pm »
Yes.
« Reply #12 on: July 30, 2022, 08:31:11 pm »
No don’t bother with a 351c . Too big ,too heavy .
  • Name: Fred
« Reply #13 on: July 30, 2022, 08:36:45 pm »
Thanks Glenn 70, very interesting. You have answered what i needed to know.  You and all the members have been Great support.
« Reply #14 on: July 30, 2022, 08:43:23 pm »
That’s what we do  :thumb: . Just a no for the 351c . Bad enough fit into a 67-70 model .
  • Name: Fred
« Reply #15 on: July 30, 2022, 08:56:18 pm »
I will keep you posted. on what i have built.  :event:
Offline hux
  • Name: Craig
« Reply #16 on: August 17, 2022, 06:37:34 pm »
Heads on the Cleveland (canted valves) are very wide compared to Windsor.   I think its been said already, a nice stroked 8.2” deck block with some decent heads is probably the easiest option.  Cleveland in 70 is not spacious
