Left over and spare parts - mostly 65/66
Author Topic: Left over and spare parts - mostly 65/66  (Read 8934 times)
Offline muzzieat9
« on: June 23, 2022, 05:49:56 pm »
Left over and spares, too many to list prices. PM me if there is anything of interest to you and we can negotiate a price.
Revolution RaceGear 4 pt harnesses (Red) - used (no expiry date type)
Davis Craig Digital Thermo fan controller (New)
Davis Craig Thermo fan pusher - used 12"
Davis Craig Thermo fan Puller - used 16"
Chrome Aircleaner with washable unifilter 11" good used
Edelbrock chrome Aircleaner base and filter 14" good used
OEM Clapper starter motor - out of 66 - works
OEM 65/66 steering wheel horn centre  & arms  - 1 x good used
Hood hinge set -raw -used
Engine pipe exhaust flange kit / cone style 2.0"
XA Master cylinder(PBR) - good used case/ suit rebuild
67 Mustang tailshaft, w/out yoke and uni's - good painted condition
Monte Carlo bar chrome - used
Acorn nuts new -  set 20
Ford racing valve cover breather - black crinkly - new
Assortment C4 pans, 2 orig, 1 aftermarket with drain plug
65 tranny hard lines - v/good used
Assortment of orig 65 dash pad mouldings 1 long, 3 curved
65 quarter mouldings (sharks teeth) - used
65/66  brake line, soft one to diff - new
8" Ford diff hemisphere - used
OEM 65/66 headlight surrounds / eyebrows - used, 1 x crack
Headlight buckets 65/66
disk brake splash shields, Kelsey Hayes / SSBC
65/66 Pony deluxe internal door pull handles x set
Rear spring plates 65/66 used - some wear at shock attachment point
65/66 used full handbrake cable set
Phillips original radio - not working when removed
65/66 rear tail light assemblies x 2
65/66 Battery tray - used
Underdash handbrake mechanism - used
65/66 OEM horn set - used
OEM Number plate light - used
OEM Door hinges - upper and lower
Used voltage regulator OEM
65/66 good used interior mirror OEM
Petrol caps x 2 - used condition
2 x set wiper arms / blades
Grill horse corrall for 66 - used
Bumper over riders / reay 65/66
Under dask air intake vent -used
67/68 drivers mirror / interior adjust type - used
Wheel splash shields - used
Shifter base / cover 65/66
1" rear lowering block set - new
65/66 front shock strut brace set / arms x 2
[s]Tri colour running horse emblem set  / stick on type[/s]
66 OEM door handle set - used
2 x US number plates / both California
65/66 kick panel upholstery set (new)
exhaust hanger brackets
range of radiator support brackets
set of 65 / 66 grill surround moulds - old OEM
Heater mechanism plate / mould 65/66 - good used
Thanks : Darrell
« Last Edit: August 07, 2022, 05:29:38 pm by muzzieat9 »
Online fredm666
  • Name: federico
  • Car: 64.5 D-code - 55 Cusso
Re: Left over and spare parts - mostly 65/66
« Reply #1 on: June 23, 2022, 08:29:41 pm »
Hi Darrell, Where are you located?
fred
Offline muzzieat9
« Reply #2 on: June 24, 2022, 05:44:00 pm »
Parts are in Canberra
Offline muzzieat9
« Reply #3 on: July 01, 2022, 08:39:21 pm »
Bump
Online fredm666
  • Name: federico
« Reply #4 on: July 04, 2022, 08:12:37 pm »
Is the radio an original one out of a ‘66?
Do you know the reason why it is not working?
fred
Offline muzzieat9
« Reply #5 on: July 05, 2022, 06:48:20 pm »
Hi Fred, came with the car. Its never worked and I don't know why. TTuning knobs move the dial, the push buttons hardly move it anymore.
Its stamped FOMOCO on the underside, had FORD in the front window and Phillco AR-14 under the tuning knob.
Offline unilec5544
  • Name: Neil.
« Reply #6 on: July 06, 2022, 01:08:51 am »
Message sent to muzzieat9
Offline 65 mustang
  • Name: SHANE BARGAS
  • Car: 1965 GT Fastback
« Reply #7 on: August 05, 2022, 06:18:41 pm »
Hi do you still have parts for sale i am in Canberra would like to come over hand have alook.
Many Thanks
Shane
Offline GGT66
  • MOCA VIC Member since 2012
  • Name: George
  • Car: 66 GT Coupe
« Reply #8 on: November 25, 2022, 08:53:05 pm »
Msg sent
Offline Chris66pny
  • Name: Chris
  • Car: 66 Mustang
« Reply #9 on: January 28, 2023, 08:26:17 am »
Message sent
Offline Chris66pny
  • Name: Chris
  • Car: 66 Mustang
« Reply #10 on: March 03, 2023, 03:52:26 pm »
Hi, wondering if the 8" hemisphere is still available?
Offline frankenstang65
« Reply #11 on: April 01, 2023, 03:37:38 pm »
Hi do you have the under dash air intake vent ?
