Yukon Gear Ford 9" Rear Disc Brake Conversion Kit
Author Topic: Yukon Gear Ford 9" Rear Disc Brake Conversion Kit  (Read 3578 times)
Hey all,
Has anyone come across any Yukon Gear Ford 9" Rear Disc Brake Conversion Kits before.
It has an emergency brake drum inside the brake rotors and is for the larger bearing axle housings.
Twelve months ago I needed to get my emergency brake working better, it has a centre pull handle.
So I pulled it all apart and the two piece E brake shoe was worn and had a several part numbers on it, after a week I came up with a brake shoe off a Ford Explorer. As it was I also needed to add a few pulleys on the cable to get a harder pull on the actuator levers.
But I was just looking at Yukon differentials and found Yukon make a Rear Disc Brake Conversion Kit for Ford 9” differentials.
It seems this is what I have one of these, although I have Bosch rotors.
I either have a Yukon Gear Ford 9" Rear Disc Brake Conversion Kit or they are the same as UN to US Ford Explorer brakes.
They look identical except for the rotors!
There is some stamped letters on the back of the backing plate, I’ll have to check these out sometime.
