64 1/2 Mustang Brake Master Cylinder Upgrade
Author Topic: 64 1/2 Mustang Brake Master Cylinder Upgrade  (Read 2459 times)
Offline Moostang
  • Name: Brian
  • Car: 64 1/2 Mustang
« on: February 08, 2022, 09:37:56 pm »
Hello, newbie to the forum. looking for advice. Bought a 64 /14 mustang and trying to get it to a reasonable condition. (it runs). It has a single bowl master cylinder with a brake booster. Can this be upgraded to a dual bowl with the existing booster? Not sure if there is enough room. Also not sure what the spec is on the booster. The car has drum brakes all round. Thanks in advance for any advice. Attached are pics of what I have.
Offline 289 vert
Re: 64 1/2 Mustang Brake Master Cylinder Upgrade
« Reply #1 on: February 12, 2022, 12:50:06 pm »
No
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
« Reply #2 on: February 12, 2022, 01:10:30 pm »
You might be able to upgrade the booster and master as a unit though.
https://leedbrakes.com/i-19296455-7-inch-power-booster-1-inch-bore-master-drum-drum-zinc.html
Think there are similar ones around.
That one is for automatic transmission cars.
I’d be slightly concerned as to what mods were done to get the unit you have fitted, in to your car.
Maybe talk to a brake expert.
« Last Edit: February 12, 2022, 01:14:00 pm by Clubman7 »
Offline fredm666
  • Name: federico
  • Car: 64.5 D-code - 55 Cusso
« Reply #3 on: February 12, 2022, 10:08:20 pm »
If you have enough budget I would change with disc brake at the front.
fred
