Idle Speed with York A/C
Author Topic: Idle Speed with York A/C  (Read 4576 times)
Offline seany-boy
  • Car: 1970 Mach1
« on: November 24, 2021, 08:53:00 pm »
so just wondering what the experience is or the typical setup for folks with a York A/c. (next time it breaks I think a Sanden is going in).
So I think it is typical that the York is a bit of a strain on the engine - although I read about some differences with the a/c charge- and in my case that lowers the idle almost to a stall particularly when cold.
I suspect this is not uncommon but please correct me if I am wrong. What do folks normally do about this, run at a higher idle than normal or do I have a different issue?.
Ahaaa, just read the thread able the idle up solenoid  should've searched better. https://forum.mustang.org.au/index.php/topic,22790.msg227545/topicseen.html#msg227545
So what is the experience and is this the only way to solve it? Manual 4 spd.
« Last Edit: November 24, 2021, 09:56:51 pm by seany-boy »
Offline Shep69
Re: Idle Speed with York A/C
« Reply #1 on: November 25, 2021, 02:19:33 pm »
I had to use a idle up solenoid with my sanden compressor also. Works a treat.
Offline seany-boy
  • Car: 1970 Mach1
« Reply #2 on: November 28, 2021, 08:41:56 am »
cheers, I found the 70 came out with one standard so I will try one.
« Reply #3 on: December 11, 2021, 10:40:31 am »
the stock compressor should never drop the rpm by more than around 125 rpm at idle on a stock engine that is properly tuned, when it kicks on.
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #4 on: January 27, 2022, 02:18:29 pm »
I fitted idle up solenoid its adjustable and works a treat
does anyone remember laughter
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #5 on: January 27, 2022, 02:24:52 pm »
A common problem for York compressors is vibration.
If anyone's interested I do have the solution.
It don't laugh its called a vibration bar and fitted stock but most have been removed over the years.
also don't forget the idler pulley.
I can barely tell when the compressor cycles
Offline seany-boy
  • Car: 1970 Mach1
« Reply #6 on: January 27, 2022, 02:47:36 pm »
I sourced an original solenoid and bought a bracket, just need to do some modifying of the bracket to fit around the linkages of my later model holley.
Offline Steve428
  • Name: Steve
  • Car: 1970 428 CJ
« Reply #7 on: January 28, 2022, 03:17:01 pm »
Hi Pete
Do you have any pictures of the anti vibration system ?. I have an original York compressor on my car and it does vibrate at lower revs.
Cheers Steve
Offline seany-boy
  • Car: 1970 Mach1
« Reply #8 on: January 28, 2022, 08:08:45 pm »
intriguing discussion, made me do some searching too.
This thread has some interesting info and a google search shows a bar from the top of the York to the engine further back. Not sure if this was only used on early years as all the reference seems to be 65ish.
Also some comments about an additional fixed pulley which might assist.
https://www.vintage-mustang.com/threads/1965-mustang-a-c.1025809/
Again not sure what years each are pertinent to, hopefully Pete or someone else has more info.
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #9 on: January 31, 2022, 09:25:06 am »
Photo attached. I made mine as a prototype and worked so well pained and installed.
« Last Edit: January 31, 2022, 09:26:47 am by pmb0186 »
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #10 on: January 31, 2022, 09:33:04 am »
Picture off the web
Offline Steve428
  • Name: Steve
  • Car: 1970 428 CJ
« Reply #11 on: January 31, 2022, 12:47:04 pm »
Thanks for posting the pictures. Much appreciated
I will fabricate a bracket for mine (428engine) and see how it goes.
Steve
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #12 on: February 01, 2022, 11:04:20 pm »
Share your results once you fabricated and fit your  bar
Offline Steve428
  • Name: Steve
  • Car: 1970 428 CJ
« Reply #13 on: February 02, 2022, 08:37:15 am »
Will do. Away at the moment and will look at making a bracket next weekend.
Offline Steve428
  • Name: Steve
  • Car: 1970 428 CJ
« Reply #14 on: February 10, 2022, 04:54:52 pm »
Hi guys
Well I made a bracket from round 12mm, bolted it to rear corner of the air con compressor and back to the intake manifold stud. My car has a shaker so the support bracket for the air cleaner has a stud on the intake so it was an easy fix.
Very happy with the result, virtually no vibration in the car at any speed so highly recommend anyone with the old style compressor to fit a bracket. Worth the effort.
Steve
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #15 on: February 16, 2022, 10:55:38 pm »
Well done thanks for the reply
