Engine and trans swap info
Author Topic: Engine and trans swap info  (Read 2958 times)
Offline 66dreama
« on: September 25, 2021, 12:18:15 am »
Hi all
Looking for advice and know it will be somewhere but need a link / direction please
Looking at a complete engine trans swap
Have a wrecked series 2 au xr8 tickford Ute
Want to swap engine and trans ( btr ) and keep efi
This will be going into my project 54 mainline Ute so planning on using as much gear as practical
Any info and advice greatly appreciated
Cheers all
Re: Engine and trans swap info
« Reply #1 on: September 25, 2021, 06:41:11 am »
Hey dreama,
Nice timing, there is a similar question about this combination on pre 73 part of forum.
Going into a Mainline do you want to keep the carburettor look.
Offline 66dreama
« Reply #2 on: September 25, 2021, 10:43:42 am »
Hi Phil
Thinking to keep engine as is with efi setup
Plan is to use as much of the au loom as possible
Ie lights indicators fuse and distribution box etc
Have the motor and driveline installation sorted but want to find out what I can and can’t delete from the loom
I read posts way back where guys had done similar but can’t find them
Any help would be appreciated
Paul
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #3 on: September 25, 2021, 01:09:06 pm »
Paul,
I fitted an NC Fairlane engine and trans in to mine,
I removed everything from the loom except what was needed to make it run.
Really you can leave as much or as little of the original loom as you want.
I needed a bypass module fitted to the ECU for the smartlock disable.
This will be much harder with the AU doner as they run smartshield and are much more sophisticated.
You may need to keep the body module and ignition switch from the AU.
This is what I removed from the loom.
Peter.
Offline 66dreama
« Reply #4 on: September 25, 2021, 01:48:23 pm »
Hey Peter
Thanks for the reply
I have the all elecs including the key and transponder unit
Yes smartshield bypass does seem a bit more involved than  smarlock and I haven’t been able to find much info as yet hoping someone who has done this will chime in.
My hope is I can strip the loom of features I no longer need but run the car through the remainder
Paul
PS please jump in anyone who can help
Offline efi Coupe
  • Name: Dave
« Reply #5 on: October 05, 2021, 10:19:01 pm »
Hi -
Yep Have an AU3 TE50 Engine in my 66
Jason Bolger from TI performance did a J3 chip for me - worked a treat.
Changed it from Auto to Manual for me
Give me a call or email if you'd like to know more
Offline 66dreama
« Reply #6 on: October 06, 2021, 09:52:04 am »
thanks Dave
it would be great to talk
 Ive sent you an email with my number
cheers
Paul
Offline scedd1
  • Name: Steve
« Reply #7 on: October 06, 2021, 11:03:45 am »
I did an EL conversion on my 68 coupe Frankenstang, but i used everything - motor, box, diff, wiring Loom, dash, computers, steering wheel, cruise, EFI, Fuel Tank top, the lot.
Only problem i had was the smartlock kept telling me the back doors were open  :lmao: :lmao: :lmao:
.  ____________
./____________ \.
 ( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
 |___|            |___|
« Reply #8 on: October 06, 2021, 11:19:28 am »
Did you end up hiding a pair of rear door locks under the seats to fix it :bolt:
Offline 66dreama
« Reply #9 on: October 06, 2021, 06:06:21 pm »
hey Steve
Im planning to use as much as i can from the donor
were you / can you point to any online info for the harness stripping
thanks
Paul
Offline scedd1
  • Name: Steve
« Reply #10 on: October 07, 2021, 06:17:34 am »
Worse, i put it in the too hard basket, to look at another day.
15 years later i still havent got around to it.
Next year, after the move to Bargara, i will spend some time on it, including a heart transplant.
.  ____________
./____________ \.
\_ o _ _____ _ o _/
 |___|            |___|
Offline scedd1
  • Name: Steve
« Reply #11 on: October 07, 2021, 06:19:03 am »
hey Steve
thanks
Paul
I was a bit slack there and didnt strip anything off the loom, but i needed almost everything as i transferred the whole dash and all the computers.
.  ____________
./____________ \.
\_ o _ _____ _ o _/
 |___|            |___|
