69 fastback fuel tank
Author Topic: 69 fastback fuel tank  (Read 1652 times)
Offline Tanner18
« on: July 26, 2021, 03:15:37 pm »
Hi all,
I'm in the market for a 69 fuel tank, if anyone has one laying around, please let me know.
Re: 69 fastback fuel tank
« Reply #1 on: July 26, 2021, 05:11:57 pm »
Hey Tanner,
Have you got a rust leak at the bottom of the tank!
I did so I emptied the tank and drilled and fitted a brass bung at the hole.
Also helps if you want to drain your tank.
Just drain your tank, blown air through your tank out of the inlet and use a breast drill to drill the hole.
Insert brass fitting like a nutsert (through your sender unit hole) so it expands and holds in place, use a copper washer to seal and fit a brass threaded bung.
You may get a few more years out of it!
« Reply #2 on: July 26, 2021, 06:04:06 pm »
This is the bung I fitted!
Offline Tanner18
« Reply #3 on: July 26, 2021, 06:11:26 pm »
Hi Aussie Phil,
Thanks for your advice, I don't have a fuel tank, I need one to line up my trunk floors.
« Reply #4 on: July 27, 2021, 06:49:00 am »
Hi Aussie Phil,
Hey Tanner18,
Looking back at your posts your at the early stages of your build.
Best of luck, enjoy building your 69 Mustang.
